pops out of gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2009, 11:33 AM   #1 (permalink)
self-proclaimed geenyus
jermyjerm's Avatar
View jermyjerm's Photo Gallery
Gen5 pops out of gear
for about a week now,my shifter would visibly move forward and backward in fifth gear corresponding to throttle inputs.now it spits it right out of gear.im thinking either bent shift fork or broken powertrain mount.opinions??
jermyjerm is offline   Reply With Quote
Old 03-07-2009, 11:49 AM   #2 (permalink)
pedron
Guest
Posts: n/a
View pedron's Photo Gallery
sounds like a broken motor mount to me.
Old 03-07-2009, 08:02 PM   #3 (permalink)
View 89molavi's Photo Gallery
From the post it sounds like this is a manual transmission. Sounds like the 5th synchroniser is gone. How many miles on the car?
89molavi is offline   Reply With Quote
Old 03-07-2009, 09:04 PM   #4 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $318510
View gdanaher's Photo Gallery
If the shifter was rocking around in all gears as you varied the engine rpm then I would guess a bad motor mount. It isn't the shifting fork unless you have it badly adjusted and there is no play. If it is happening only in 5th gear then the gear set itself is maladjusted, chipped, or worn. Again here, likely not the synchronizer. More likely a chipped gear.
gdanaher is offline   Reply With Quote
Old 03-07-2009, 10:36 PM   #5 (permalink)
Redline_Me's Avatar
Gameroom cash: $335135
View Redline_Me's Photo Gallery
Mine does the same in first gear when i go to switch into second. It feels and sounds bad. I'm bringing my car back to the dealer before i do my mods. Last time they tried it i had them drive the car for a while but it didnt do it..go figure.
Redline_Me is offline   Reply With Quote
Old 03-07-2009, 10:58 PM   #6 (permalink)
Tremendous_Slouch's Avatar
View Tremendous_Slouch's Photo Gallery
bad synchro in the trans. Replace or rebuild it unless you like being annoyed. It is a h igh mileage car no doubt, sorry but theres no patch or quick fix.
I had good luck once with a junkyard unit it served me well for quite a while. If you intend to keep the car a long time, id go for the rebuild.
Tremendous_Slouch is offline   Reply With Quote
Old 03-08-2009, 05:06 AM   #7 (permalink)
View omairtheman1's Photo Gallery
my car does not do this... LE 2002 manual trans
omairtheman1 is offline   Reply With Quote
Old 03-08-2009, 07:45 PM   #8 (permalink)
The Connoisseur
CharmCityES's Avatar
sounds like maybe you could have a chipped or worn gear if it is only in 5th gear, because i know that when ive had cars popping out of all gears it was usually bad motor mounts..
The "Executive Sedan"
Old 03-09-2009, 12:49 AM   #9 (permalink)
View mcdawgg's Photo Gallery
I had an '84 Corolla that did this - it was a bad 5th gear synchronizer.
mcdawgg is offline   Reply With Quote
Old 03-09-2009, 03:27 AM   #10 (permalink)
instead of getting it actually rebuilt i am sure you can find one of a camry or a scion for cheap... its highly developed and probably easy to find then pop a new clutch in while your at it and that should be a fun 5-6 hours... well 4 if i do it
Old 03-09-2009, 03:45 AM   #11 (permalink)
yahhh true its much cheaper but i was just staring at the major picture...
Old 03-09-2009, 01:33 PM   #12 (permalink)
jermyjerm's Avatar
well,i removed the engine movement control mount and it was broken so i filled it with polyurethane and fabricated a solid steel replacement to test my theory.it still pops out of 5th.and a solid engine mount sounds like garbage!i was happy to put the real mount back in once the polyurethane dried.it will go into 5th,it will coast all day in 5th,but as soon as i apply throttle-patooey,spits it right out.im leaning toward broken gear.
Old 03-09-2009, 01:52 PM   #13 (permalink)
View camryvibe's Photo Gallery
Yes, our '87 Nova/Corolla has had the same problem for the last 50,000 miles. Fortunately it gets just as good highway gas mileage (about 45) cruising in 4th as it ever did in 5th and is only a little noisier. Apparently this was a pretty common problem in high-mileage Corollas of that vintage since I've run into a couple other people who experienced the same issue.
camryvibe is offline   Reply With Quote
Old 03-09-2009, 02:53 PM   #14 (permalink)
View sniper34's Photo Gallery
Tranny mount.
sniper34 is offline   Reply With Quote
Old 03-09-2009, 05:19 PM   #15 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Maybe dumping the clutch and pounding the living piss out of your car and posting vids of you doing it helped your transmission problem? Maybe not...
2006 Camry LE Special Edition
