12 volt light wiring question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2009, 01:41 PM   #1 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $531607
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Hey, do any of you guys understand these instructions? I'm trying to figure out which wires I can splice to install some of these lights in my car. I want to put them on the door so when I open it, it'll light up.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 Neochromes - More on the way
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 03-07-2009, 01:53 PM   #2 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
what's so difficult - black to chassis ground, black/white to power (+12V)...
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 03-07-2009, 01:54 PM   #3 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
View ebumdude's Photo Gallery
The easiest that I would do, is the two wires that are for the door light right on the bottom of the door.
Take a flat head or a scribe, and pop the light cover right out.
Mount your light wherever you desire.
One wire from the factory door light is +
One wire from the factory door light is -
Splice them right into that, and it will work.
Seal your connections you made securely, and wa-la.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 03-07-2009, 02:02 PM   #4 (permalink)
TN の がしょう
xpeed's Avatar
^ Thanks, it's only because of the DC12V and the ground that confused me. I'll go check it out.
Old 03-07-2009, 04:31 PM   #5 (permalink)
ebumdude's Avatar
No problem. Let us know how it turns out.
-09' Venza
Old 03-07-2009, 04:39 PM   #6 (permalink)
Gameroom cash: $201860
View CamrySExxx's Photo Gallery
Hit the nail right on the head
CamrySExxx is offline   Reply With Quote
Old 03-07-2009, 04:46 PM   #7 (permalink)
TN の がしょう
xpeed's Avatar
I just realized that the Gen 5 doesn't have the lights on the doors. I might have to pry open the door covers to get to the wires.
Old 03-07-2009, 04:53 PM   #8 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $283505
View MrSo0h0o's Photo Gallery
What are you trying to do exactly? I have done pretty extensive work taking on and off the door panels so I can help with what you need.
MrSo0h0o is offline   Reply With Quote
Old 03-07-2009, 04:55 PM   #9 (permalink)
ebumdude's Avatar
I did not realize you had a GEN5. I do not know if there are pre-existing wires or not. Sorry for the no help.
Unless, you have done the CCFL footwell mod that many of us on here have done. Then you could just piggy back off the wiring from that.
-09' Venza
Old 03-08-2009, 10:51 PM   #10 (permalink)
TN の がしょう
xpeed's Avatar
I basically want to install these LED spot lights on my door so that I can have "puddle lights" when I open it. Are there any type of 12v wires in the doors that I can splice and install to? I might have to make a custom housing for the lights to fit cleanly which means I might have to drill some holes into the plastic covers on the door.
ebumdude: no I haven't done a footwell conversion so I probably can't do the wirings from that.
Old 03-08-2009, 10:58 PM   #11 (permalink)
MrSo0h0o's Avatar
You can probably tap off the window controls. This will provide power from acc to 15secs after key out of the ignition and no door is opened. The issue now is finding it lol.. Maybe check out the wiring diagrams to find out what color the +12v is
Old 03-08-2009, 11:53 PM   #12 (permalink)
But once the door is opened it will shut off will it not? And that would mean it would be on all the time? Well when the key is in the ignition.
Old 03-08-2009, 11:55 PM   #13 (permalink)
Honestly though the best bet would wire it to your domelight.
That's what most people do with puddle lights.
http://www.youtube.com/watch?v=Gvraxl1uipI
There is a example. Same concept, I did my footwells based off that concept since I didnt feel like doing all the extra work for the puddle lights under the side skirt.
Old 03-08-2009, 11:57 PM   #14 (permalink)
MrSo0h0o's Avatar
right right right... i just listed a 12v source... lets see.... the only possible way i can see you getting the same effect you stated (on when door opens, off when closed) is wire it to the dome light. That would require running it from the door, through the door jamb, up the A or B pillar, and across to the middle of the roof..
Old 03-09-2009, 04:43 AM   #15 (permalink)
TN の がしょう
xpeed's Avatar
Hmmm, I might have to buy some more wires then cause the wires for these are too short. I'll open up the door and see which wires I can use to have the desired effect I need.
