power folding LED turn signal wiring diagram help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2009, 10:12 PM   #1 (permalink)
bleachigo's Avatar
Gameroom cash: $237005
View bleachigo's Photo Gallery
Hey everyone.Just wanted to know if anyone here can tell me where to find any sort of wiring diagram for my power folding turn signal mirrors.I've used the search function and read some threads but none of them have really specific wiring walkthroughs and parts that i need for a DIY.Also the search function gets unreliable sometimes when i throw a bunch of words to search.Anyways,I know njerald has the same available functions on the mirrors that i have(not sure if he got it at the same place)so i will pm him also if he could help me.Any sort of help from anyone else is appreciated.Thanks guys.
07 red XLE V6,SE grille,Megan coils,Nokya 7K Arctic White fogs,LED int.& ext.,pwrfolding,heated turn sgnl mirrors,5k HID,UR sb&rsb,LED door handles,25% tint,Sprtwing roof splr,JDM lic.plate hldr,JDM sidemarker,JDM mirror switch,AVS slim visors,ass shave,F5 CAI,cut shifter
bleachigo is offline   Reply With Quote
Old 03-07-2009, 10:48 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Do you have factory heated mirrors now?
Do you want to put a switch in for the fold function?
Old 03-07-2009, 11:52 PM   #3 (permalink)
bleachigo's Avatar
Yes it is heated.I just need a good diagram of all the wiring and where it goes and parts to get to get it going.I saw your some of your post when you got yours and i think you had a hard time with the people where you bought the mirror where they didn't provide any diagram and connectors and things like that.That's what i'm going through right now.I am trying to contact them but these people are unresponsive.And yes i do want to install a switch.
Old 03-08-2009, 01:00 AM   #4 (permalink)
'07 XLE
Gen6
It is very easy to identify the wires and function examining the mirror.
After identifying , it is easy to check all functions except heat using a 9v, 12v, 15v battery from a hand power tool.
Mine were:
Heat = Black-white and Black-white
LED = Purple and Black
Horizontal = Red and Brown (as a common)
Vertical = Blue (uses brown above as a common)
Fold = White and Grey
I have no idea what yours are. If you installed the covers without tracing, testing and identifying wire colors, good luck............
I cut off the new mirror connectors and added 9 pin radio shack connecors for removing the mirror if needed in the future.
http://www.radioshack.com/family/ind...goryId=2032286
You have to run 4 wires behind the instrument panel from the left kick panel area to the right hand mirror signal and fold functions.
Tie into the right and left turn signal wiring in the left kick panel.
Run power to the switch and auto fold wiring from both mirrors to the switch.
Figure out all existing wire colors (mirrors, turn signal, power tie in)connectors and locations ahead of time.
I did my diagram in my head and checked every connection and function as I went.
Have fun.
Old 03-08-2009, 04:04 AM   #5 (permalink)
bleachigo's Avatar
Thanks.I will try what you suggested.I was also thinking of auto fold when turning car off and auto fold when turning car on.What do you think is needed for that to happen?
Old 03-09-2009, 05:03 PM   #6 (permalink)
'07 XLE
Gen6
I think it's a ridiculous setup but you could do it with relays........tie into a ignition enabled power source.
Old 03-09-2009, 08:39 PM   #7 (permalink)
Shady Camry
View zhugeliang's Photo Gallery
If you plan to go with this option with the ignition, be sure to set to the power off mechanism. So once you open the doors, everything will power off ASAP.
PS: Njerald is "tha man" !
'07 Titanium LE I4 (Heated Leather Seats), Brushed Aluminum Dash-Kit, Auto-Folding LED Turn-Signaling Mirrors, 6,000k H.I.D., Bluebatmobile Eyelids, Trunk Accent Upper and Lower Grille, Handles, Door Sills with blue Camry light, White LED swapped and LED Tail Lights
zhugeliang is offline   Reply With Quote
Old 03-09-2009, 09:51 PM   #8 (permalink)
'07 XLE
Gen6
Originally Posted by k.toyoda View Post
why is it ridiculous?
If you have to drive in or out of a tight place/garage, you want the mirrors folded when the car is moving.................................maybe it's not an obvious concept to you.
Old 03-09-2009, 10:12 PM   #9 (permalink)
bleachigo's Avatar
Been busy with work so haven't wired up the mirrors but all the wiring colors are exactly as yours,njerald.Now just got to look which wires are for the turn signals.As for the supplies,i "borrowed" some 6 pin and 4 pin molex connectors,and some male and female terminals and a few feet of 22 gauge wires(it pays to work at an electronic manufacturing company sometimes)
