2003 Camry, 4cyl, 85k miles. The Check Engine Light recently went on. I had the code pulled at a local parts store, and the report was "Catalyst efficiency low bank 1". Their probable cause list is:
- Defective cat
- Misfire or running condition
- Large vacuum leak
- Oil leaking into exhaust - valve guide seals / rings
Interestingly, when I started the car to take it to the parts store and have the code checked, it puffed some light blue smoke (which I hadn't observed previously).
My rationale is telling me that there's a high likelihood that the valve seals are going, and that is the root of the problem.
I'm interested in knowing who does, and doesn't, agree with that notion, and *why*. I'm also interested in knowing the best tests (and the order in which to do them) to perform to properly diag the root cause *before* tearing parts down for repair.
*IF* it turns out to be the valve guide seals - is this an undertaking for a mechanically inclined person (I previously tore down the 6cyl on my Tacoma to do the timing belt and water pump)? Or, is this best left to the pros?
If I've left out anything important, please let me know.
How much oil has the engine actually used in how many miles? It would need to blow a LOT of oil out the exhaust before it fouled the emissions system, and generally worn valve seals won't permit THAT much oil past, or certainly not that much, all of a sudden. The cheapest check is the oxygen sensor as previously stated. Check the existing sensor with your ohm meter and compare the value to a new one. Without even a manual, if the values are hugely discrepant then it needs replacement, even if it isn't the immediate source of the problem, and it's cheaper to replace than the cat.
Secondly, make sure the pvc valve is clear and that the ventilation system in the valve cover is clear as well. Any engine can have sludge and that sludge can clog the vent and force oil past the seals.
It isn't unusual for the valve seals to show wear at 85k miles but it would be unusual for them to be leaking enough to cause problems with the sensors.
- It is *my* belief that the issue is with the valve seals. Not the cat, not the O2 sensor. The valve seals.
- If you agree with me, or not, I'm interested in WHY so I better understand the reasoning process for diagnosing this.
- What tests should be run, and in what order, to actually determine if this is an issue with the valve seals or not.
I believe that replacing an O2 sensor at this stage is NOT a wise path to take. The blue color of the cold-start exhausts is indicative of a bigger issue that needs to be corrected FIRST. And, I'll just have to replace the O2 sensor AGAIN after fixing that problem.
To address the questions about oil consumption - I honestly don't know that it has been burning an appreciable amount of oil, if any, until at least recently. And, I can't actually measure the burn because I don't know when the issue ultimately started. I agree that the chances of enough oil through the exhaust to foul the cat is HIGHLY unlikely (the car would be blowing a lot of smoke, and would have for quite some time).
I will definitely check the PCV and vent - I hadn't really thought a lot about that, but it does make a lot of sense that an overrun of pressure could cause the *appearance* of a seal leak.
I agree that the blue smoke at startup is a typical symptom of leaking valve guide seals. A compression test would firm up the diagnosis. Low compression could also be due to piston rings so a test is to squirt a bit of oil into the cylinders and repeat. If the problem is rings then the oil will seal them temporarily and raise the comp. reading. Valve guide seals will still show low compression.
But, like gdanaher, I'm skeptical that this is the cause of the CEL if it's just a brief puff at startup. For awhile our '97 Camry was emitting a real cloud of blue smoke both at startup and whenever we slowed down for awhile on long trips and then started up again. This was enough to completely obscure the view of anything behind us in the rearview mirror. But it did not throw a CEL, nor did it prevent the car from passing Calif. enhanced emissions testing (15 and 25 mph dyno test).
With respect to the compression test, I respectfully disagree. Valve stem seals are separate and apart from the valve heads. You could have a burned valve and never burn oil through the seal and vice versa.
I'd take the oil cap off and then find the inlet for the pvc valve. Fabricate a hose that will seal to that opening and blow air into the valve cover. Note air coming out of the oil filler opening. Air should flow very freely. If there is any obstruction at all, then this is the likely culprit and needs to be cleaned out.
I had mentioned my thoughts as to what the issue was, and asked for some comments around whether I was on the right track or off my rocker.
I got a couple of comments to "do this" or "do that" without some rationale as to why.
Here's what has transpired so far:
I got someone to provide a solid recommendation for a local mechanic (someone that would tell me straight up if I should be trying to correct the issue once the issue was definitively determined). That person told me that the "flowchart" used to check the symptoms I was describing was to replace both O2 sensors as a first pass. The reasoning was that a) based on experience there's a decent chance this is the ultimate problem and b) it "made sense" to chase a fairly easy and (comparatively) cheap repair (about $300 for both sensors and the PCV) compared to a valve seal job.
The mechanic told me that they don't do valve seal jobs on these motors because of the very tight tolerances and the potential for things to "go wrong, quickly" once the bolts holding down the camshaft are loosened. So, I asked for a referral of a good dealer and got one.
I called the dealer and discussed this briefly with them. What I was told was that the late 90's motors definitely had issues with valve seals, but there was not an abundance of similar problems with the motors in the 03s. The likelihood of there being a valve seal issue was low. I was also told that this motor uses a timing CHAIN, not a belt. So, there would be no cost savings to do a valve seal job and timing belt together.
Moreover, I did get a rough-order cost estimate of $1,500 (assuming no head machining, replacement or repair required) to do the seals if it turns out that those are at fault.
I wasn't done. I kept digging and found specific information online about how to locate and CHECK the O2 sensors, which I did. As it turns out, the Before Cat sensor is shot (infinite load measured with an ohmmeter) and the after cat is showing some wear (13.9Ohms and valid range 11-16) but definitely in working order.
So, I'm going to replace the before cat sensor this weekend and see what happens. Total cost for that and a PCV is about $125. If it clears the issue up, I'll do the after cat sensor the following weekend and call it good (I was told that they should be replaced in pairs, and they are near their check/replace interval of 100,000 miles anyhow).
Here's an update on what I've done so far and the current status. Last night, I started the replacement process of some parts to determine if the problem can be easily corrected by me. Here's what I did:
- Pulled the negative lead from the battery
- Pulled the four bolts holding the heat shield over the exhaust manifold
- Unplugged the O2 sensor (the one before the cat, under this heat shield) and removed the shield
- Removed the O2 sensor
- Installed new Bosch O2 sensor (13733) that I bought from a local parts store for about $120
- Re-installed the heat shield
- Connected the new O2 sensor to the wiring harness
This whole process took about 15 minutes.
- Removed the cover on top of the valve cover (the one that covers the plugs)
- Removed the vacuum hose from the PCV
- Removed the PCV
- Installed a new PCV
- Re-attached the vacuum line
- Re-installed the cover
- Re-connected the battery
This whole process took about 10 minutes.
Total job, about 25 minutes, $130 for parts. CEL is currently off and I will be embarking on a journey of monitoring any change in gas mileage and/or performance. I will also be watching for the light to come back on.
Side note: I did a cursory check of the PCV, and I believe there's a high chance it's blocked as I wasn't able to feel any air pass through it when I blew against the manifold side (I did the exact same kind of check against the new one and felt quite a bit of air passing through). I'm hoping that there's a high chance of there being "too much" pressure inside the valve area, and that being related to the slight amount of oil that's clearly getting into the piston chamber.
I'll be monitoring, and will post an update when I have something meaningful to pass along.
