Advice on removing bulb out of socket in trunk? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2009, 05:42 PM   #1 (permalink)
The O-Sho
Omer's Avatar
View Omer's Photo Gallery
Gen6 Advice on removing bulb out of socket in trunk?
So I'm about to put my 2 12" LED strips in the trunk but I need to remove the old stock bulb out of the socket so I can plug in the adapter to connect them to.
I just went outside and tried for like 10 minutes to remove it, it seems jammed in there pretty tight. My fingers hurt from all the squeezing and pulling, and ultimately I just gave up.
Do you guys have any tips on how I can get it out easier?
http://www.cardomain.com/ride/2456437
2007 Camry LE (Magnetic Gray Metallic)
Mods: 6000K Apexcone HID Kit, Interior Footwell LEDs, Chrome Grille Accents, Kydo 9005 Hyper White High Beams
Omer is offline   Reply With Quote
Old 03-13-2009, 06:36 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
lol it is a bitch, but here is what I did remove the plastic housing of where the bulb is in and then unplug the bulb. Its alot easier to get the bulb out when your not upside down.
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 03-13-2009, 06:47 PM   #3 (permalink)
2GR
Toyota Tech
View 2GR's Photo Gallery
I've done a thousand of them and all you do is twist counter clockwise til it stops, pull it out of the tail light, And then pull the bulb out.
2GR is offline   Reply With Quote
Old 03-13-2009, 06:51 PM   #4 (permalink)
"Everyone Lies"
Dna_splice's Avatar
View Dna_splice's Photo Gallery
WTF^??
He is talking about trunk dome light.
Try and grab it near the base.
Mine was stuck also. I was afraid to break it when squeezing
And get glass on my fingers...
'03 SE i4 <3
"Si vis amari ama"[If you want to be loved, love.]
Dna_splice is offline   Reply With Quote
Old 03-13-2009, 07:04 PM   #5 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
take it out, unclip the harness. Bring it inside and work on it there. If you want try wedging something small in there and pry it out.
CamrySExxx is offline   Reply With Quote
Old 03-13-2009, 08:16 PM   #6 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
Use some latex or rubber gloves, it'll give you grip, then pull it out.
GT-R is offline   Reply With Quote
Old 03-14-2009, 04:06 AM   #7 (permalink)
The O-Sho
Omer's Avatar
How do you unclip the harness safely? I'm scared of breaking the connection.
Old 03-14-2009, 09:27 AM   #8 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
there is a little push tab on the harness plug itself....push, then pull simultaneously.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 03-14-2009, 10:01 AM   #9 (permalink)
money042's Avatar
View money042's Photo Gallery
Are you trying to pull out the wedge bulb? or the whole harness?
If it's the bulb, I like the latex/rubber gloves recommended above. If you don't have those, try a rubber band. I can't imagine it being stuck that bad.
For the harness, maybe needle nose pliers.
2007 Camry SE V6 - SOLD 7/30/09
money042 is offline   Reply With Quote
Old 03-14-2009, 10:08 AM   #10 (permalink)
ebumdude's Avatar
i used needle nose pliers for the bulb too.
-09' Venza
Old 03-14-2009, 10:23 AM   #11 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
If only the bulb...
Use a carrot cut to size, push it in to seat firmly, then twist. IF it's the wedge kind, yare...pliers.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
