DIY: Gen 5 [2002-2006] Climate Control Bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2009, 10:45 PM   #1 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Gen5 DIY: Gen 5 [2002-2006] Climate Control Bulbs
Alright, I finally put together a DIY on how to change the climate control bulbs, along with the (apparently) elusive part number. Hope this is helpful
Basically you just need to pry the climate control panel out, I covered a screw driver with a microfiber towel so I wouldn't scratch anything. There are six clips which come out fairly easily. Once you get the panel out there are two plugs - just unplug them, they're both big and unique so you won't get them mixed up.
You don't have to unscrew the backing of the panel, the bulbs have blue bases and just twist out. Remove the burnt out ones and replace it with the new bulbs. Then all you have to do is attach the two plugs and snap everything back into place.
Symptoms of burnt out climate control panel bulbs:
- Intermittent light
- Hitting the panel will sometimes bring the bulbs back to life for days/weeks at a time
- Two knobs out at one time (there are only TWO bulbs, one illuminates two knobs, just FYI)
Part number: 90011-11050 @ $4.61 each
(That last picture is just for fun, it's my new TN decal )
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
The Following 3 Users Say Thank You to islandboy57 For This Useful Post:
AACE2 (12-29-2010), gn2 (08-05-2011), xx03Camryxx (04-16-2011)
Old 03-13-2009, 10:52 PM   #2 (permalink)
View PittsburghCeli's Photo Gallery
Where did you get the cool tn decal? Nice bulb job btw
91 Celica GT Coupe
Knowledge builds confidence.
PittsburghCeli is offline   Reply With Quote
Old 03-13-2009, 11:05 PM   #3 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
good writeup, but was this ever an issue of accessing them??? ive taken that panel off and accessed the bulbs numerous times already
MrSo0h0o is offline   Reply With Quote
Old 03-13-2009, 11:41 PM   #4 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
good write up but i thought you change the bulb color or somthing, there is also a dyi for this already
LoudCamry is offline   Reply With Quote
Old 03-14-2009, 10:38 AM   #5 (permalink)
View razdigital's Photo Gallery
Nice TN decal.
> Loud Camry where is the other write up DYI?
Went to Autozone they didn't have it. Went by the Toyota Dealership they had a few picked up one for $4.15. We'll see how well it lights up at night(no garage).
razdigital is offline   Reply With Quote
Old 03-14-2009, 12:36 PM   #6 (permalink)
LoudCamry's Avatar
you can buy the bulb from the dealer, it is around 3-5 dollar
Old 03-14-2009, 01:18 PM   #7 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Yes, that's what post #1 says...........
Old 03-15-2009, 12:55 AM   #8 (permalink)
& JustAnotherCamry
View JustAnotherAsian's Photo Gallery
alternative generic bulb number might be #74, but i have to check...
nice simple writeup.
JustAnotherAsian is offline   Reply With Quote
Old 03-15-2009, 10:48 AM   #9 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
you shoulda usa LEDS dude!
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 03-15-2009, 04:04 PM   #10 (permalink)
vvti-me's Avatar
View vvti-me's Photo Gallery
anyone know the size of this bulb? ill probably throw some leds in mine.
someone said i think #74 but any for sures?
vvti-me is offline   Reply With Quote
Old 03-16-2009, 07:44 PM   #11 (permalink)
Originally Posted by razdigital View Post
Nice TN decal.
Yeah I didn't see a previous DIY and nobody volunteered info in the other thread I/we were posting in regarding the climate control panel/bulbs. I also couldn't find the bulbs aftermarket and decided to just get regular incandescent bulbs from the dealer. LEDs crossed my mind but I wasn't sure about the viewing angle from such a small LED.
Anyway, as long as this DIY helps at least one person, I'm happy.
moving forward
Old 03-18-2009, 10:42 PM   #12 (permalink)
View andrelaplume's Photo Gallery
Be Happy---thanks!!!!!!
andrelaplume is offline   Reply With Quote
Old 03-25-2009, 11:51 AM   #13 (permalink)
AWESOME. I did it the other day. Bilbs were $3.30 at the dealer...took a ady for them to get them. It took less than 10 minutes to follow your procedure...I did not even have to disconnect the climate control panel once it was removed. Thanks again.
Old 06-09-2009, 11:56 PM   #14 (permalink)
The Moose
modified_camry's Avatar
View modified_camry's Photo Gallery
thank you so much. i have had this problem for a long time, and thought it was a short in a wiring or something.. fixed today in 5 minutes. thanks man!
2004 Toyota Camry LE-
Enkei 17's, TRD Sway Bar, 05 SE Grille, SE Headights, De-badged, Smoked Tails
modified_camry is offline   Reply With Quote
Old 06-10-2009, 07:41 AM   #15 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
I just noticed these are the same type of bulbs on my 2002 Honda Odyssey. The bulb on the minivan also went out. Smacking it would also potentially bring the bulb back as it seems to be a known problem. However the bulbs for the Odyssey is really small. I got the replacement from Radio Shack.
I dont have a Gen 5, so what size is the bulbs for those who want to get LEDs. There are 3mm, 4mm and 5mm. Looking at the picture and size of the bulb, it looks like 5mm.
LEDs would cost you $1.30-$3.49 (depending where and which on you buy).
CarDomain
