2007+ Camry Valentine One Installation Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2009, 05:02 PM   #1 (permalink)
View cdangdrive's Photo Gallery
Hey All,
Does anyone know of an easily accessible 12V switched wire in the 2007+ Camry that I can tap into in order to install my Valentine 1 Radar Detector?
I'd rather not have to use a fuse tap if I can just find the right switched wire.
Thanks!
cdangdrive is offline   Reply With Quote
Old 03-14-2009, 05:44 PM   #2 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
Do you have a moonroof? If so, it would be very easy just to tap into the moonroof wires.
If you don't have a moonroof, you might have to run the wire down to the lower dash and connect it to the radio power wire or any other wire that turns on with the car.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 03-14-2009, 08:04 PM   #3 (permalink)
Don M's Avatar
View Don M's Photo Gallery
Blend Mount has a power tap option if you have the auto darkening mirror. The mount is a nice accessory and well made. I have not used the power tap.
Don M is offline   Reply With Quote
Old 03-14-2009, 11:18 PM   #4 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
All I did was buy Valentines 8 foot flat cord. Attached my V1 to my blendmount. Ran the wire across the headliner, down the passenger pillar, across the glove box and into the side access of the cubby hole and connected to the cigarette adapter. Thats my "hard wire"
CarDomain
Old 03-15-2009, 11:26 PM   #5 (permalink)
View r0ng5's Photo Gallery
i ran it from up top, above the rearview mirror and down the driver side pillar, under the dash and tapped into the 12V powerpoint inside the cubby. I used a 12 ft phone cord and it was just enough.
2004 Ford Ranger (a few things done to it)
2004 Lexus GS300 (pretty much stock)
2007 Toyota Camry LE (girlfriend's car, my project =D )
r0ng5 is offline   Reply With Quote
Old 03-17-2009, 10:38 AM   #6 (permalink)
ghz
View ghz's Photo Gallery
Can you post more pics? I want to see how you ran the wire under the dash to the cubby. I also have a V1 and I'd love to figure out a way to hide the wire.
ghz is offline   Reply With Quote
Old 03-17-2009, 10:44 AM   #7 (permalink)
that's the only picture i have... but I just took off the pillars on the side of the cubby, then took off the screw. Then I removed the trim piece for the shifter (you have to remove the shifter). Then I shimmy'd the cubby out. Then I tapped into the wires w/ my Valentine direct-power kit. Then I ran a telephone cord up along the side of the dash (driver side).
One other tip, I also removed the "tweeter" cover so I can run the phone cord easier. It was simply a snap off/snap on thing. Um... I think that's it. It's pretty straight forward.
Old 03-17-2009, 10:45 AM   #8 (permalink)
nuchieboy's Avatar
Gameroom cash: $203299
View nuchieboy's Photo Gallery
Gen6
how did u get the v1 to mount on those bubbles around the mirror..i couldnt get it to stick there so i had to mount it more towards the passenger side
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 03-17-2009, 10:52 AM   #9 (permalink)
I went super high-tech with this problem.
I used two layers of clear packaging tape. You can barely see it and it works
Just remember to put the packaging tape on very nicely. No creases or bubbles.
