fried HID harness relay - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2009, 12:13 PM   #1 (permalink)
Cathode Protector
View cosism's Photo Gallery
Lightbulb fried HID harness relay
I am creating this thread just to underscore my findings so it may help another user who is appropriately using the search function.
Most folks know to use a relay harness when running an HID setup. I am currently running a retrofit which consists of: TSX clear lenses (color modded), Phillips 85122+ burners, and Gen 3 Hella/Phillips LVQ-212 300s ballasts.
A few days ago my lights did not come on. I checked the 30A fuse right after the + side of the battery and was good (continuity checked). I found 12V going into the relay from the battery and only 200ish mV coming out towards the ballasts. I disconnected the relay from the socket and found this...
Turns out, a lot of these relay plugs are not water tight. I went to Pep Boys and found another 12V/40A relay for $10.99. After plugging the new one in, the lights fired up. Turns out, the PLACEMENT of the relay was not all that great. I do have an SE model and have that splash guard down there (by the fogs) but water sure found it's way into the relay.
I used sealant on the new relay where the leads go into the receptacle (female socket) and where the relay itself (plug) meets the socket. I also moved the relay to higher ground and tied it "prongs down", so water would not fill it, as I had the relay "prongs up" and the water filled the relay and was not able to escape with gravity.
I hope others can use this as a trouble shooting tool when searching the boards for problems with HIDS firing up. One thing i should mention is that I checked all of the leads for continuity while I was down there, and this should be a part of your troubleshooting checklist.
07' SE V6, TSX retro w/ color mod, Chrome 18" GS430 wheels, led bulb swaps, tinted windows, K&N drop-in, Sirius, door moldings(FTMFW!!!!). 2 Britax seats too!
cosism is offline   Reply With Quote
Old 03-17-2009, 12:18 PM   #2 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
This is very helpful! It nice of you to think of others....
Old 03-17-2009, 12:19 PM   #3 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
A few days ago my lights did not come on. I checked the 30A fuse right after the + side of the battery and was good (continuity checked). I found 12V going into the relay and only 200ish mV coming out. I disconnected the relay from the socket and found this...
Thanks, that is very helpful indeed. What brand was the relay harness (or did I miss that)?
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 03-17-2009, 12:22 PM   #4 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Wow, that thing was drowning in a pool of water!
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 03-17-2009, 12:24 PM   #5 (permalink)
Cathode Protector
Just following your example Wally.
You are welcome Tolbeit. I omitted that info, sorry. I purchased this relay on ebay. By the looks of other relays (like relays that are sold on these boards) most of them do not seem to be sealed. When someone is installing their harness for the first time (or when troubleshooting), sealing and moving to higher ground should be a recommendation.
Old 03-17-2009, 12:30 PM   #6 (permalink)
Cathode Protector
Yeah, pretty nasty. The relay itself was not submerged but the opening where the leads from the battery, the ballasts and the frame/ground(-) was facing up. We had a downpour out here a little while ago, and we have some streets that get a tad flooded.
Old 03-17-2009, 02:30 PM   #7 (permalink)
LOV
268 HP OWNER
LOV's Avatar
View LOV's Photo Gallery
Thanks for this info, now i will move my relay a bit higher.
2007 Camry SE V6 , MGM
LOV is offline   Reply With Quote
Old 03-17-2009, 03:00 PM   #8 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
Hey, thanks for the info... this should get stickied
My Partial Partout!!!
Photo Album
Old 03-17-2009, 03:27 PM   #9 (permalink)
2009 Camry SE I4 MGM
glenn14's Avatar
Gameroom cash: $339325
View glenn14's Photo Gallery
Gen6
cosism,
The same thing happened to me when I had my FX35 bi-xenon retrofit in my
Altima, what I did was enclose the relay in a waterproof box made out of plastic and sealed it with silicone. And I never had that problem again. And if the relay malfunctioned I could always cut open the box with a razor knife where I sealed it off. I thought that I would throw this info out there too for
anyone who needs an Idea on how to keep the relays dry. I am going to to
do this on my Camry once I install my retrofitted lights.
Glenn
2009 Camry SE MODS:
Blacked Out Headlights with MDX D2S Retrofit,TSX-R Clear Lens, 85122+D2S Bulbs, G2 Red Painted Calipers, W.T.Floor Liners, Rosen Navi. GEN6.5 Chrome Wheels, XD Digital 35 watt ballasts, H11 Wire Harness, Megan fstb.
glenn14 is offline   Reply With Quote
