Low coolant level but no leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2009, 06:01 PM   #1 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
I have a 2002 Camry V6. I checked the coolant level and it's about at L mark, when engine is cold. I don't see any visible leaks. I had my water pump changed last year in march.
Any ideas what is happening to the coolant? Engine oil seems to be fine and tranny fluid seems normal (red).
Thanks in advance.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 03-18-2009, 06:14 PM   #2 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
Even though this is a closed system your coolant still may evaporate.
It could be a tiny leak that evaporates on the hot engine. Look for traces of coolant under the radiator cap.
Top it off and watch closely.
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 03-18-2009, 06:17 PM   #3 (permalink)
LoudCamry's Avatar
Gameroom cash: $229927
View LoudCamry's Photo Gallery
i have no idea but sometime when i look under my hood the coolant is low then the next time i look at it agian it at normal level.
LoudCamry is offline   Reply With Quote
Old 03-18-2009, 06:30 PM   #4 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Check it warm, Bet the level rises......
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 03-18-2009, 10:02 PM   #5 (permalink)
2002 Camry
coolant reservoir
Is my Coolant Reservoir missing a piece? see red circle. Is there suppose to be another hose that connects to it or some kind of plug? Thanks
Old 03-18-2009, 10:14 PM   #6 (permalink)
icqboy51's Avatar
View icqboy51's Photo Gallery
i have a 2003 V6, and the Coolant Reservoir is like that on mine also.
if after using your car, park overnight, then check underneath. if no leaks, then no leaks.
just top off the coolant to Full and watch it over next days/ weeks.
icqboy51 is offline   Reply With Quote
Old 03-18-2009, 10:26 PM   #7 (permalink)
LoudCamry's Avatar
it not missing a piece, i believe that part is for air to be release when the coolant flow back and fourth
Old 03-18-2009, 10:43 PM   #8 (permalink)
2002 Camry
But leaks can be internal as well How often do you need to top off your coolant since you had your car?
Old 03-18-2009, 10:45 PM   #9 (permalink)
icqboy51's Avatar
in that case, then might need professional to check it over since it would be hard to check yourself right?
Old 03-18-2009, 10:47 PM   #10 (permalink)
LoudCamry's Avatar
i haven't top off my car since about 3 years, i recently just did a coolant drain and refill
Old 03-19-2009, 07:34 AM   #11 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
When the engine warms up, the coolant expands and is under pressure and the extra coolant needs somewhere to go. Thats why theres an overflow tank, the thing you're talking about. Thats why it appears as full when the engines warm.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 03-28-2009, 10:10 PM   #12 (permalink)
Tremendous_Slouch's Avatar
View Tremendous_Slouch's Photo Gallery
It may be simply normal! The cooling system works like this, when engine is cold your coolant bottle level is at Low. When you run the engine it gets hot, the engine can overflow coolant when hot and running, it is designed to blow into the coolant recovery tank, thats what it is there for and this is completely normal.
When you shut off the engine, as it cools it reverses the process, excess coolant from the bottle is supposed to be sucked back into the radiator. This is how a closed cooling system is designed to work and this is probably what explains why you noticed the level in the bottle changing.
Fill your coolant recovery bottle to max mark with engine cold. It ought to stay that way for quite a while. If you have to do this every week, then yes you may have an internal engine leak like a blown head gasket - or your coolant bottle may just have a pinhole crack - or some other minor problem like a weepy hose end from a loose hose clamp.
Tremendous_Slouch is offline   Reply With Quote
