drained Transmission fluid color - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2009, 08:03 AM   #1 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
When a transmission is healthy, what color should the drained transmission fluid be? Or should I say, is it clear or opaque? If it's red opaque, is that normal.
Before the drain, if I look at the transmission dipstick, it's red and clear because it's such a small quantity, but once drained into a pan, it's red opaque (or somewhat translucent). Is this normal?
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 03-19-2009, 01:44 PM   #2 (permalink)
2002 Camry
Somebody must know. I just want to check if my transmission fluid is being contaminated with coolant.
Old 03-19-2009, 03:02 PM   #3 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
The transmission could not be contaminated with coolant unless you poured coolant into it. It is fine
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 03-19-2009, 05:55 PM   #4 (permalink)
2002 Camry
Correct me if I'm wrong, but don't some radiators also cool transmissions. There are tubes that enter into the radiator and if there is a leak in the tube coolant can enter the transmission. Maybe this does not apply to Toyota Camry's.
Old 03-19-2009, 06:30 PM   #5 (permalink)
JSM1284's Avatar
That could be a possibility, yet rare. As long as the fluid didn't look like a strawberry milkshake, its fine. Red, and slightly translucent is normal.
2005 Lexus ES330
Old 03-19-2009, 07:04 PM   #6 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Mine came out a dark red/purple color @ 30K miles/36 months. I did two drain/refills and shift quality definitely improved. I'll probably do one drain/refill each year from here on out.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 03-19-2009, 08:43 PM   #7 (permalink)
The Connoisseur
CharmCityES's Avatar
it should be a dark red and slightly translucent....and according to your description you should be in the clear
if it looks like used oil and smells burnt, you have a problem
The "Executive Sedan"
Old 03-19-2009, 09:00 PM   #8 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
look at my website for your answer.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 03-20-2009, 08:25 AM   #9 (permalink)
2002 Camry
I checked your section on "how to change ATF fluid" and with all due respect it is terrible. (sorry, I have to be brutally honest, just like a Simon Cowell). You show a few pictures of the drain plug, tranny fluid, etc, but left out the most important information when it comes to changing ATF fluid, such as how to check the level, check when engine is warm, move the shift through all the gears first, etc. If the ATF smells burnt or if it smells sweet, etc, etc. Overall, very poor and misleading info, you can end up killing someones tranny if someone overfills. When tranny fluid is not check under proper conditions.
Besides, where's my answer from your website???
Old 03-20-2009, 06:07 PM   #10 (permalink)
the critic's Avatar
View the critic's Photo Gallery
Dark red or dark brown is normal. As long as the paper towel isn't pitch black after wiping the dipstick, it's fine.
It's normal for the fluid to darken as it accumulates miles. If the transmission uses a carbon fiber type friction material, the fluid will darken significantly but this does not mean that there is a problem with the transmission.
the critic is offline   Reply With Quote
Old 03-21-2009, 09:58 AM   #11 (permalink)
carlo$'s Avatar
your question was: what color....
In my video I show a couple of shots of the color of the old fluid and I state how nasty it looked at 63,000 miles.
Did I not answer your question?
You did not ask any other questions in your post.
FWIW, all information in these forums should be taken as reference material only. For specific information and legal advise one must consult the manufacturer's manual or a certified toyota technician.
2005 LE 4 cyl
Old 03-21-2009, 10:34 PM   #12 (permalink)
2002 Camry
Ok thanks. Of course, your not liable, but if you put "how to change ATF" you might want to add a couple of statements such as "make sure car is in normal operating temperature, keep the car running and put in Park, check the fluid level." It's only a few lines, might saves someone tranny.
