Can lowering springs be improperly installed? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2009, 01:14 PM   #1 (permalink)
bleachigo's Avatar
Gameroom cash: $244505
View bleachigo's Photo Gallery
Hey guys just wanted to know if lowering springs can be installed improperly?My car has been out of alignment for a while now.The car was lowered at a local sportshop then later i went to the dealers and told them that my car was out of alignment and they recommended me to get camber bolts.The labor costs was a bit pricey so i went to get the camber bolts and alignment done at an outside shop.Outside shop aligned it twice and they said that they don't know why the car is still drifting to the left and all the numbers are in spec.So i went back to the dealership,they tried aligning it twice also and it still drifts to the left.So i went to measure my fender gaps and the front driver side of the car has a 2 finger gap while the passenger side has 3 finger gap with no load on the car whatsoever and on a level road.The rear on the driver's side is a little harder to tell but it's about maybe half a finger lower then the passenger side.I'm going back to the shop where i lowered my car and talk to him about this.So what do you guys think?Is it possible to install it wrong?Or could it be something else like a bad strut and shock?
07 red XLE V6,SE grille,Megan coils,Nokya 7K Arctic White fogs,LED int.& ext.,pwrfolding,heated turn sgnl mirrors,5k HID,UR sb&rsb,LED door handles,25% tint,Sprtwing roof splr,JDM lic.plate hldr,JDM sidemarker,JDM mirror switch,AVS slim visors,ass shave,F5 CAI,cut shifter
bleachigo is offline   Reply With Quote
Old 03-21-2009, 01:33 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
There is one way to do it right and dozens of ways to screw up. What are the odds?
gdanaher is offline   Reply With Quote
Old 03-21-2009, 02:55 PM   #3 (permalink)
View toyomoho's Photo Gallery
The cars chassis should sit level. If not take it back to the spring installer and have them fix it.
Old 03-21-2009, 03:01 PM   #4 (permalink)
"Everyone Lies"
Dna_splice's Avatar
View Dna_splice's Photo Gallery
yeh its possible.
but hard to say wht it is w/out seeing it
'03 SE i4 <3
"Si vis amari ama"[If you want to be loved, love.]
Dna_splice is offline   Reply With Quote
Old 03-22-2009, 07:45 AM   #5 (permalink)
View omairtheman1's Photo Gallery
go see the guys that installed the springs man...
stories like this make it hard to trust shops
omairtheman1 is offline   Reply With Quote
Old 03-22-2009, 11:16 AM   #6 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
I love these adventures.......
Old 03-22-2009, 12:19 PM   #7 (permalink)
money042's Avatar
View money042's Photo Gallery
I just installed my springs myself this past week. I really can't see anyways to mess it up (at least what you’re describing). I can only imagine the shop missed one (or two) springs, hence one side of the car being higher than the other. Get a flash light and take a look into your wheel well to see if all 4 springs are indeed H&R springs (H&R springs are dark metallic blue). Maybe the shop only swapped out one side... sounds ridiculous, but who knows...
you got any pictures?
2007 Camry SE V6 - SOLD 7/30/09
money042 is offline   Reply With Quote
Old 03-22-2009, 12:25 PM   #8 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
Was it hard to instal them yourself? I'm thinking about doing mine. I have seen the DIY, but im just a little scared about messing something up.
Redline_Me is offline   Reply With Quote
Old 03-22-2009, 12:58 PM   #9 (permalink)
2007 Camry SE V6
Gameroom cash: $133290
View thrawnis's Photo Gallery
Are the springs for the front and rear different types? If so, maybe they put one front and one rear spring both on the front, and same on the back?
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is offline   Reply With Quote
Old 03-22-2009, 01:04 PM   #10 (permalink)
It says it right on the spring, next to the part number if they are for the front or rear.
Old 03-22-2009, 01:10 PM   #11 (permalink)
money042's Avatar
I did springs then switched to coils for my Altima a couple years back. I messed up pretty bad doing the springs (first time attempting anything like that). The CV joint on the passenger side got dislocated, I had to pull the boot off and put the joint back togther and then put the boot back on. It was a big mess, those things are filled with grease. Where I messed up was I took out all three bolts on top of the strut (accessed from under the hood) before taking out the bolts that attach the strut to the whatchamacallit (wheel/caliper/rotor/etc) part. So the strut just fell out and pulled the whatchamacallit further than it was supposed to go, dislocating the CV joint. Took me 3 days to get the car working again. I've got pictures on my storage harddrive somewhere if you're interested, just PM your email. To make a long story shorter, Altima has shocks in the back, so those were easy. But gen6 Camry has struts on all four corners AND the rear top mounts can only be accessed via taking the rear seats out (a pain in the a$$ on the SE). So it's a little more work. Overall, took me 5 hours by myself (if you have a buddy to hold stuff and help, that would be ideal) but I have some experience with the Altima. I also changed a buddy's shocks and struts. So I did similar projects three times. Oh, maybe four time, if you want to count removing the coils and going back to factory before selling the Altima. If you do try
this yourself, make sure you have a backup car (or a mountain bike, like me ) if you need a tool from the store or it takes longer than you plan and you have to go to work the next day. But bottom line, there's nothing like the satisfaction of finishing a project like this. I love doing it. Maybe I'll open a shop one day
bleachigo, sorry for hijacking your thread.
Old 03-22-2009, 01:30 PM   #12 (permalink)
Well spending $900 on some parts that i hadn't really planned on has set me back on my instal and paint budget so i'm thinking about saving myself the $200 and doing it myself. Plus as you said there is nothing better than doing it with your own hands. Thanks for all the info.
sorry bleachigo.
Old 03-22-2009, 01:36 PM   #13 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
you can't mix up front and rear - they won't fit at all.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 03-22-2009, 03:10 PM   #14 (permalink)
View camryi4's Photo Gallery
any one notice njerald never gives helpful advice?
camryi4 is offline   Reply With Quote
Old 03-22-2009, 05:54 PM   #15 (permalink)
lets all be nice now...
