Coolant Dilemma! Ok to use Green coolant in a Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2009, 02:57 PM   #1 (permalink)
View mgold8's Photo Gallery
I have a 2002 Camry SE. I was recently checking all the fluids on the car and noticed that the coolant level was considerable low. I checked my garage for some coolant and saw I had some AutoPride Coolant & AntiFreeze. I mixed it with some distilled water doing the suggested 50/50 mixture. I then realized before I put in the mixed coolant that it was Green and the coolant in the coolant tank was Red!
I'm wondering is it ok to use this Green coolant in the car? Will I harm anything by using it? I know a lot of these coolants you buy in stores basically work in all cars no matter the color. It usually says that on the bottle though and it didn't on this AutoPride coolant. I feel like it should be fine since I used this mixture in another car. What are all the Toyota experts opinions about this?
mgold8 is offline   Reply With Quote
Old 03-22-2009, 03:11 PM   #2 (permalink)
icqboy51's Avatar
View icqboy51's Photo Gallery
do a quick search and you will find the answer within 2 minutes.
post a common/ already answered question, you will not get an answer quick... cause they will just tell you to use the search function.
and you might get flamed big time by njer.
icqboy51 is offline   Reply With Quote
Old 03-22-2009, 03:18 PM   #3 (permalink)
LoudCamry's Avatar
Gameroom cash: $229927
View LoudCamry's Photo Gallery
i am not to sure about mixing coolant, you can buy toyota red cooland at the dealership.
LoudCamry is offline   Reply With Quote
Old 03-22-2009, 04:57 PM   #4 (permalink)
View 89molavi's Photo Gallery
The color does not mean much nowadays. You have to check the contents and the type. Toyota uses their own coolant which happen to be red. I am not sure if it is a HOAT coolant or no. I would say it is safer to flush and refill with Toyota coolant, but also doubt anything would happen soon if you didn't. You are reducing the life of the water pump and the seals and gaskets.
89molavi is offline   Reply With Quote
Old 03-22-2009, 08:56 PM   #5 (permalink)
The Connoisseur
CharmCityES's Avatar
never mix coolants....
you own a toyota, and it calls for the red coolant...theres a reason why toyota reccomends the red coolant (it is better at preventing rust inside the motor) so you should use what toyota reccomends!
The "Executive Sedan"
Old 03-23-2009, 12:42 AM   #6 (permalink)
em3
View em3's Photo Gallery
Agreed. Don't mix coolants. Could cause chemical reactions
em3 is offline   Reply With Quote
Old 03-23-2009, 01:34 AM   #7 (permalink)
on full afterburner
Gameroom cash: $1342897
From my experience, you shouldn't mix the coolant, but switching colors is okay provided that you do a complete flushing of the cars cooling system. I've been running Prestone Green coolant in my Corolla for 3 years with no problems but am planning on switching back to Toyota Red this summer.
However, if you are still under factory warranty I wouldn't recommend that you do so.
Old 03-23-2009, 09:17 AM   #8 (permalink)
Well.... I've probably done a lot of things that Toyota doesn't recommend for the car, bit it's not like anything bad has happened to it. Isn't it better to have coolant in the car rather than non at all even if it's not the exact coolant you are supposed to get?
This car is important to me and I want it to last a long time. I guess I should try to find some Red 50/50 coolant to be safe. How do I tell what the color it is when I go to the auto parts store? It's not like the bottles are clear!
Old 03-23-2009, 09:20 AM   #9 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
buy it from the dealer!
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 03-23-2009, 09:26 AM   #10 (permalink)
MMmmmm, I'd really rather not! That's really expensive!
Is there a cheaper way to get it online? Is there some other coolant which is basically the same which I could get in an auto-parts store?
Old 03-23-2009, 11:15 AM   #11 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
how about using tap water?
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 03-23-2009, 11:16 AM   #12 (permalink)
View GeorgiaHybrid's Photo Gallery
Try reading this for some more info on antifreeze. There are several types but you CAN mix as long as they are from a compatible family. Toyota is not the ONLY car company to use a HOAT style of antifreeze.
http://www.geocities.com/dtmcbride/h...ntifreeze.html
GeorgiaHybrid is offline   Reply With Quote
Old 03-23-2009, 11:18 AM   #13 (permalink)
carlo,
Always use distilled water to mix with antifreeze or go ahead and buy a 50/50 mixture
Old 03-23-2009, 11:31 AM   #14 (permalink)
Gameroom cash: $103555
View laphan's Photo Gallery
It is not that expensive. I paid $17.60 for 1 gallon (includes 6% MI tax) from my local dealer. It is not that bad since the cheapest coolant from walmart cost around $8 per gallon.
'08 Toyota Camry Hybrid
'00 Grand Marquis LS (winter beater)
'04 Porsche Boxster
Gone: '06 Solara
laphan is offline   Reply With Quote
Old 03-28-2009, 10:01 PM   #15 (permalink)
Tremendous_Slouch's Avatar
View Tremendous_Slouch's Photo Gallery
At work we use a Prestone coolant that is compatible with all other coolants. Says so on the jug.
When in doubt and short on cash (like most people reading this are or we wouldnt be here) just use this kind of coolant.
There are two opinions on red vs green coolant, the "long life" red coolant used in GM, Ford and some foreign brands (but not toyota coolant as far as i know)has been found to clump up inside the engine when changed at the recommended interval (50,000 miles i think).
On the other hand i used green coolant on my 1988 Nissan pickup for the entire time i owned it (RIP, i had to get rid of her last year at 289,000 miles when she wouldnt smog). I changed coolant about once a year. Still had the original radiator when i junked it and not a trace of leak or corrosion.
Tremendous_Slouch is offline   Reply With Quote
