New tires making noise. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2009, 10:22 AM   #1 (permalink)
snake212's Avatar
View snake212's Photo Gallery
Gen6 New tires making noise.
i bought 4 new Yokohama tires back in mid February for my 2008 Camry SE. these tires were recommended by the salesman to be the most quietest tires. so after the install i drove back home on the freeway at about 70 to 80 mph and he was right it was smooth and quiet. now in early march the front tires started making this noise as if the front tires were off balance when going over 40mph but with no vibration on the steering wheel. so i took it back and told them the problem and he said that it might be the suspension causing the tire to unevenly break in. so he said they rotated the tires from side to side, and the tires were already balanced.They still make that noise and if anything it got worse. Could a defective tire make that noise? because i dont think its a suspension problem its a new car.
snake212 is offline   Reply With Quote
Old 03-27-2009, 11:50 AM   #2 (permalink)
nj0ywatch1np0rn's Avatar
View nj0ywatch1np0rn's Photo Gallery
What tires are they?
From experience, the salesman or advisor know very little when it comes to cars. Most probably don't even know where to put the oil in the engine!
2007 Camry SE
nj0ywatch1np0rn is offline   Reply With Quote
Old 03-27-2009, 11:56 AM   #3 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
Usually tires make road noise when they are new, so this is pretty weird. How's your alignment? Does the car pull to any side when you are going straight?
Redline_Me is offline   Reply With Quote
Old 03-27-2009, 11:59 AM   #4 (permalink)
snake212's Avatar
i got the Yokohama YK520. i got the alignment done the next day and no pull perfect alignment.
Old 03-27-2009, 12:02 PM   #5 (permalink)
Is the noise like a constant humming sound? Or a vibrating sound?
Old 03-27-2009, 12:05 PM   #6 (permalink)
snake212's Avatar
vibration sound. as if i got off road tires put on.
Old 03-27-2009, 12:09 PM   #7 (permalink)
View eddiefromcali's Photo Gallery
most tires get louder as they wear down...what does the tread depth look like?
07 Camry LE V6 - TRD drop, Fujita CAI, IS350 Wheels, SE Grille
eddiefromcali is offline   Reply With Quote
Old 03-27-2009, 12:15 PM   #8 (permalink)
snake212's Avatar
they are barely a month old. maybe 10/32
Old 03-27-2009, 12:17 PM   #9 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Move the front tires to the back and see if noise moves to the back. If yes, then it's your tires. Not likely all 4 tires are defective or making noise, but it possible if it's a bad batch.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 03-27-2009, 12:21 PM   #10 (permalink)
snake212's Avatar
i will try that today.
Old 03-27-2009, 12:25 PM   #11 (permalink)
It could be uneven ware, flat-spot or maybe even control arm bushings. Try bringing it to the dealer.
Old 03-27-2009, 12:27 PM   #12 (permalink)
snake212's Avatar
but what will cause the uneven ware?
Old 03-27-2009, 12:34 PM   #13 (permalink)
Alignment. It can be thrown off just by hitting a bad pothole. When did you get it done? If the noise is that bad and that constant, you should be able to notice it on the tires.
Old 03-27-2009, 12:48 PM   #14 (permalink)
snake212's Avatar
i did the alignment about 2 to 3 weeks ago
Old 03-27-2009, 12:49 PM   #15 (permalink)
2002 Camry
Another thing to look for? Which is sometimes obvious but may be overlooked. Check to see you don't have any rocks/nails between the treads.
Awhile back, I got a nail stuck in one of my tires and it made a noise. Checked carefully and noticed a nail was stuck. removed nail, patched it and it was fine.
