its pretty much the same, gen 3 and gen 5 at least in terms of the front brakes. you should have no problems following the gen DIY for your gen 5. one thing i would do differently than the DIY you linked, is only undo the bottom bolt... that way you can just swing up the caliper and use a string or a hanger to hang the caliper on the spring so that its not hanging by the hose.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
