Knock sensor tends to go off in combo with other sensors if they malfunction and a knock is observed.
The problem could be your o2 sensor or knock or both, but I doubt it.
The codes just mean that the reading at those sensors are off spec, not necessarily that they are broken.
I've heard of this exact combination of codes, yes exact, knock and o2 at the same time, and the problem was the coils/wires. If you have original coils/wires with that kind of mileage, I am sure that is the problem. When did you last change your plugs, wires, and/or coils?
