Originally Posted by socalrat
1. I assume #1 cylinder on the 3.3l V-6 is the front left as you face the car?
2. On the belt it has a single line mark and a double line mark. Is the single line single mark for the left cam and the double mark for the right cam?
3. If the crank and cam are not moved does it even matter. I mean could you just put the belt on in similar fashion to taking it off?
Thanks, great site and I've gleaned some new insight already.
Garry
1. Yes but you shouldnt need that as a reference just for a tb change.
2. The best way to figure out what the marks are for, assuming your old belt is intact, is to get to the point where your cam covers are off and align all your marks on the engine with the old belt. all three belt marks may be worn away by now, but if all three engine marks are aligned just mark the belt with white out where the dots on the engine line up with the belt. Then remove the old belt and compare it to the new one and this will tell you what the marks on the new belt mean.
Beware it is possible to put your new belt on BACKWARDS causing lots of confusion when you go to crank it up and the engine wont run right! So also mark arrows on the old belt with an arrow pointing "out" or whatever works for you and orient the new belt exactly the same way as the old one.
3. No, dont try to cut corners here unless you want to do the belt install all over again! Align all 3 marks first and make sure engine is at TDC before removing old belt, then put new one on the same way as the old one.
The reason is belt slack, the belt tensioner is what takes up the slack in operation but when you put the new belt on the tensioner is not installed. Once the tensioner is reinstalled it takes up all the slack, install your belt wrong and it might run wrong even if you lined up all the marks. Your old tb is worn thus a few mm longer than the new belt due to stretching, and if you simply slide the new one on there with no reference to the engine marks theres a good chance you could be one or more teeth off - making all your hard work pointless since the engine wont run right.
Follow the procedure in the link below and you'll probably get it right the first time.
Changing V6 Timing Belt Pics and the $270 Coil Connector
