Dealership just did a Computerized Precision Alignment... car now pulls to the right - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2009, 06:36 PM   #1 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
Has this happened to anyone? My car was fine but I wanted to do an alignment with my usual service, so had tires balanced, rotated, and did the 4 wheel alignment along with the 15K factory service.
Soo... I'm going to drive it some more but car definitely feels like it's pulling to the right.
Anyone know how these things can screw up? They even printed out the Alignment report, showing the initlal and corrected #s.
MJZ is offline   Reply With Quote
Old 05-05-2009, 06:42 PM   #2 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477210
iTrader Score: 12 reviews
View bandit's Photo Gallery
Take it back to them. All that computerized info and prints shows the alignment on the wheels only but not how they installed it on the car.
CarDomain
Old 05-05-2009, 06:55 PM   #3 (permalink)
MJZ
Bulletime
MJZ's Avatar
Is there any chance something else could be the cause?
Interestingly, after about 7000 miles, my Michelin Pilot Sport A/S Plus tires still say full tread depth...
Old 05-05-2009, 07:09 PM   #4 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Was it out of alignment prior to you bringing it in for service?
Best bet is just bring it in and the dealership will try to duplicate the problem, if so, they'd just do a realignment.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 05-05-2009, 07:11 PM   #5 (permalink)
MJZ
Bulletime
MJZ's Avatar
Technically yes. The computer print out shows slight alignment deviations.
But no pulling to either side when I brought it in.
Old 05-05-2009, 08:08 PM   #6 (permalink)
"Circle of trust"
View catric69's Photo Gallery
You might want to have them cross rotate the tires.
catric69 is offline   Reply With Quote
Old 05-05-2009, 08:11 PM   #7 (permalink)
vvti
jayrguidaben's Avatar
View jayrguidaben's Photo Gallery
^^ +1 if you can switch the 2 front wheels right to left and left to right and see if there's a difference.
jayrguidaben is offline   Reply With Quote
Old 05-05-2009, 08:46 PM   #8 (permalink)
Sean89's Avatar
View Sean89's Photo Gallery
Oh wow its wierd how you post about this. I have the same issue, except for my car pulls to the left. I have not had an alignment done however. I have had them rotate the tires at my 5K service and 10K service which was last weekend. Ever since my 10K service my car is pulling to the left. Could this be something that might have happened while they rotated the tires?
I had called them and they said under warranty I have 1 alignment because my car is less than 1 year old and less than 12K miles.
Sean89 is offline   Reply With Quote
Old 05-05-2009, 09:14 PM   #9 (permalink)
MJZ
Bulletime
MJZ's Avatar
A clue seems to be the steering wheel is actually pulling. It will be straight and then you can see the steering wheel tilt noticeably to the right... and the car veers off to the right. It happens after correction to the left, even overcorrection ... repeatedly.
I'm now thinking it's a tire issue or rotation issue...
Brand new tires though (got them around 7000 miles, now the car has 14,000)
Old 05-05-2009, 10:00 PM   #10 (permalink)
Gameroom cash: $101950
iTrader Score: 6 reviews
View salvimoreno's Photo Gallery
Well obviously the steering wheel turns when the wheels turn... just playing lol
salvimoreno is offline   Reply With Quote
Old 05-05-2009, 11:21 PM   #11 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $150432
View Yazovets's Photo Gallery
Rotating your tires won't make "that" much of a difference. Just keep on insisting on having the alignment re-done until you're satisfied. Go out for a drive with the shop foreman and show him the car doesn't track straight.
The other possibility is that while doing alignment, they moved your steering wheel off center. What that means is the car may be aligned but now to go straight, the "default" position of your steering wheel is no longer dead center.
Again, that's an issue which they must fix. I fought such a battle a year ago. The dealer put in my transmission number 2 (1st one died) and because they had to dismantle some sort of front sub-frame, alignment had to be performed. I had to return twice before they made the car go straight again...
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 05-06-2009, 08:44 AM   #12 (permalink)
View 09Camry's Photo Gallery
Smile
jzh,
Could well be the tires. I recommend swapping the wheels as suggested above before going back to the alignment shop. Years ago I had a similar situation that was solved by rotating the tires. I was surprised how much a difference it made. None of the tires had any obvious defects and ran fine otherwise.
Allan
09Camry is offline   Reply With Quote
Old 05-06-2009, 11:28 AM   #13 (permalink)
Will
willt's Avatar
iTrader Score: 7 reviews
View willt's Photo Gallery
yes i had that problem. 2 months ago they guy from just tires told me i had a radial pull so i went so i back to the place where i purchase my tires and have them rotate. its still pull but just a little but its ok.
just tires told me its a tire problem but if it really bothers you get a new set
L-OO-k at MEE...
willt is offline   Reply With Quote
Old 05-06-2009, 11:37 AM   #14 (permalink)
View twinklit's Photo Gallery
I had the same problem, not with the dealer but with the tire shop I always went to, didn't think much of it until I moved and tried out another shop and everything was fine, both places were computerized alignment.
twinklit is offline   Reply With Quote
Old 05-06-2009, 11:42 AM   #15 (permalink)
Sean89's Avatar
I cant even notice my wheel move. It is only when I drive at highway speeds where slight movement will cause the car to move.
