Rear Rotors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2009, 04:46 PM   #1 (permalink)
View edbro9's Photo Gallery
Rear Rotors
I tried to remove the rear rotors on my 00 Avalon but I ran into problems. The rotor was loose and not rusted to the hub but, it seemed to be hanging up on the parking brake. Of course, I had the parking brake off. I could wiggle it back and forth and when I looked behind there, I could see the parking brake shoes moving forward with the rotor.
Is this normal? If so, how do I remove the rotor without pulling the parking brake apart? I ended up putting the new pads on the old rotor.
edbro9 is offline   Reply With Quote
Old 05-09-2009, 04:49 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
What does your Factory Service Manual say??????
Old 05-09-2009, 05:01 PM   #3 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
if you are having trouble removing the rotor because of the parking brake... you need to retract the shoes. there should be a rubber plug on the rotor... remove it, and align the hole (and rotor) with the parking shoe adjuster. the adjuster should be on the bottom. i forget which way to turn the adjuster to retract the shoes, but you should be able to figure it out
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 05-10-2009, 12:25 PM   #4 (permalink)
View johawk79's Photo Gallery
If you still have problems with getting the rotors off after adjusting the e-brake shoes you're going to have to just beat the rotors until they come off. At that point, you are likely going to have to replace the e-brake shoes and the hardware. The brake shoes are availiable aftermarket, but the hardware is going to have to come from the dealer.
johawk79 is offline   Reply With Quote
Old 05-23-2009, 02:08 PM   #5 (permalink)
View davidb4775's Photo Gallery
IF you have to beat it (as I did), hold a piece of wood (2x4) against the rotor and hit the wood and not the rotor directly, especially with a metal hammer. Hit it a few times on one side, then a couple on the other side.
davidb4775 is offline   Reply With Quote
