2003 Camry 4 cyl rattling noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2009, 08:30 AM   #1 (permalink)
View jrp5101's Photo Gallery
I have a 2003 Camry 4 cylinder with ~143K. When I start the engine I can hear a slight rattling noise. When I rev the engine the noise seems to go away (or it is just masked). I noticed the noise after the check engine light came on twice and I had it checked by an exhaust shop. The code was for an O2 sensor, but the exhaust shop said everything looked fine to them. This was about 7K ago. I jacked the car up a few weeks ago to check the exhaust for anything obvious, but couldn't find anything loose to explain the rattle. I hit the exhaust pipe with my fist and heard a rattle a few times, maybe from the catalytic converter, but I am not certain. Everything runs/operates fine, smooth acceleration, fuel economy is unchanged, engine temperature is unchanged, but the noise persists. I don't know if it is just normal due to age and nothing to really worry about, or if it is the first sign of trouble. I have also noticed that I am using about 1/2 quart of oil between changes, but I'm fairly certain that started before this noise. Your thoughts and input would be greatly appreciated!
jrp5101 is offline   Reply With Quote
Old 05-19-2009, 10:11 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Without being able to hear what the noise sounds like there's no way to accurately help you out. Can you make a video of the noise? Can you tell exactly where it's coming from? What code was stored for the O2 sensor? You can buy an automotive stethoscope for about $10 that will help you pin point where the noise is coming from.
2006 Camry LE Special Edition
Old 05-19-2009, 09:10 PM   #3 (permalink)
View Aceventura9586's Photo Gallery
One thing you might wanna check cuz I found this out on my car with a strange rattle at first start and idle. There's an inner plastic shell for the intake manifold and if ur car has enough mileage on it that shell could be falling apart. Mine was so I replaced that and it took care of the sound.
Aceventura9586 is offline   Reply With Quote
Old 05-20-2009, 01:34 PM   #4 (permalink)
View dorman68's Photo Gallery
Aceventura is 100% right. Toyota has issued a TSB addressing this issue. One more thing to look at in addition is also the belt tensioner, some of them were prone to making at rattleing sound.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 05-21-2009, 05:31 PM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
check the exhaust manifold heat shield, and the cat heatshield.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 06-10-2009, 04:13 PM   #6 (permalink)
Aceventura9586 wrote, "There's an inner plastic shell for the intake manifold and if ur car has enough mileage on it that shell could be falling apart."
Is there a DIY somewhere for this? How difficult and expensive was this?
Thanks!
