AC low pressure pot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2009, 05:13 PM   #1 (permalink)
View soarer1023's Photo Gallery
AC low pressure pot
can someone please tell me where is the AC low pressure pot is, trying to recharge the system, already search the forum but no luck. thx!!
soarer1023 is offline   Reply With Quote
Old 05-25-2009, 07:07 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Follow the hoses until you find the two valves. Attach your gauge set and read the pressures when it is running.
gdanaher is offline   Reply With Quote
Old 05-25-2009, 08:20 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Check the Interdynamics web site FAQ:
http://www.id-usa.com/how_to_faqs_recharging.asp#2
Also check out their FAQ and videos before you start. You can get frost bite or lose your eyesight with a wrong blast of refrigerant!
"2. How do I find the low-side port? The low-pressure port usually has a blue or black dust cap and is located on the larger diameter metal tubing that runs between the evaporator (in the dashboard) and the compressor. To locate the low-pressure port:
  1. Find the compressor.
  2. Find large diameter metal tubing that leads from the compressor back to the fire wall.
  3. Find port on this tube. Our quick-connect coupler should fit onto this port. To be sure, compare with the port on the other tube (smaller tube) that leads from the compressor to the condenser near the radiator. This port is larger and is the High Side port. Our quick-connect coupler will NOT fit on the High Side port.
  4. Do not attempt to connect to the high side port as this can cause a can of refrigerant to explode.
  5. Sometimes the low side port is on-or-near the compressor, sometimes it’s on an accumulator near the firewall…not on the large diameter metal tube."
