My first sub enclosure design... opinions welcome! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2009, 11:15 PM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
I know this belongs in audio, video and security or possibly even show and share(mods I would prefer it moved here if/when you do), but I thought it would be nice to get my fellow gen 5/6'ers opinions on this because I know most of you dont go to the AV and S sections. So have at it! Honest opinions are welcome!
I have 2 10" RE RE series subs on the way(should be here tmrw!!) since my old sub and amp fried, so I decided to design an enclosure. It is a dual 10" enclosure with separate airspace for each sub. I calculated the internal volume to be .635 cubes per sub. That is without the sub displacement. So net internal volume is .535 cubes. It is a pretty basic box since I do not have many tools to cut the wood(I am going to see if the local lumber company has/will cut the 3/4" MDF for me). I have the tools to put it together so I figured this would be the best aka cheapest route. Honest opinions are welcome!!
Enclosure Rendering:
Exploded View:
Top/Bottom Pieces:
Rear Piece:
Sides/Center Divide Pieces:
Face Piece:
MrSo0h0o is offline   Reply With Quote
Old 05-26-2009, 11:21 PM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Those are cool modeling screenshots! Are you sure that it's big enough for dual subs though? I mean...it's still under 2 cubic feet inside the box...is that sufficient?
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 05-26-2009, 11:34 PM   #3 (permalink)
MrSo0h0o's Avatar
Yea each sub has a separate enclosure that is .535 cubes net. Optimal internal volume is only .5 cubes as per: http://reaudio.com/specs.html#sp_re
Old 05-26-2009, 11:42 PM   #4 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
it's cool here for a bit
very nice work too!
2002 Camry SE V6 "Snow White"
Old 05-26-2009, 11:44 PM   #5 (permalink)
Do not buy from
View Zviator's Photo Gallery
damn you are hardcore ^^
Zviator is offline   Reply With Quote
Old 05-26-2009, 11:44 PM   #6 (permalink)
MrSo0h0o's Avatar
very nice work too!
thanks PND5! I just wanted to get a few hits on it. Can you put it in Show and Share after tonight?
Old 05-26-2009, 11:45 PM   #7 (permalink)
you bet
Old 05-26-2009, 11:45 PM   #8 (permalink)
MrSo0h0o's Avatar
well, I am in school for Mechanical Engineering and I work as an engineering designer for Con Edison, so its almost second nature lol
Old 05-27-2009, 12:03 AM   #9 (permalink)
Do not buy from
Off topic: Whenever people brought home furnitures from Ikea Or Lowe and tell me to build them up. I'm always surprise to see how many different type of crews and nuts, bolts and weird tools come with it. Then i'm like "Damn u engineers must have so much free time..." lol.
Old 05-27-2009, 12:08 AM   #10 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
bwahaha. Don't worry, hopefully when I finish I'll make your life even more complicated
CamrySExxx is offline   Reply With Quote
Old 05-27-2009, 12:11 AM   #11 (permalink)
If your going to a home depot or something, you can get the piece of wood and tell them to cut it for you into the sizes you want. Some will do it for free, some people will charge for each cut.
How come you didn't go for a ported enclosure?
And make sure to make pilot holes before you screw the wood down (you probably already know :P)
PS cutting a circle with a jig saw is a bit harder than it looks(well if you want a perfect circle) IMO though.
Old 05-27-2009, 12:17 AM   #12 (permalink)
MrSo0h0o's Avatar
I have read that it is hit and miss at home depot/lowe's. Some people had really nice people do a really good job and some others ended up with as big of a difference as 3/4" in their cuts!
I didn't go with a ported enclosure mainly due to space, and secondly because I want the bass to hit tighter than it did with my slot ported enclosure. I figure with double the cone area and ~100w RMS more power, I wont be losing anything.
I plan to call the local lumber shops tomorrow to see if they can cut the wood for me(possibly holes too?). I figure they will charge labor but its better than me messing up the cuts and having to scrap everything!
Old 05-27-2009, 01:22 AM   #13 (permalink)
& JustAnotherCamry
View JustAnotherAsian's Photo Gallery
deja vu (saw this on another forum that i can't speak of in here). haha.
JustAnotherAsian is offline   Reply With Quote
Old 05-27-2009, 08:28 AM   #14 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Call the shops ahead. Some of them only have radial arm saw so they can't cut sheets of material like you want. I went to one Home Depot where they said could cut any wood I buy, but when I got there they gave me a hand saw
It's likely the lumbar yards will be able to do straight cuts only so you may be on your own for the mounting holes and whatever you use for the terminals. I built a shelf out of 1/2" MDF last year and the guy at the lumber yard did pretty good. The saw they had they could put the entire sheet of MDF on to at maybe 10 to 15 degrees past vertical. They would align the sheet to the blade and the blade would go up and down to cut the material. You may want to bring or get a disposable dust mask because it tends to get dusty and MDF isn't the best stuff to breathe in considering how it's made.
Some places use 1" MDF for the front but I dunno if you need it in this situation.
2007 Camry 2.4L 5M
Old 05-27-2009, 08:46 AM   #15 (permalink)
My home depot had a saw just like this.
I gave him the sheet of paper and he just did the cuts and measurements.
