Weird smell after turning off AC - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2009, 01:19 AM   #1 (permalink)
View compfreak's Photo Gallery
I was wondering if you guy might know what might be creating this weird smell when I turn off the AC in our 07 Camry? The air smells perfectly normal when the AC is on, however after turning it off it smells weird for a few minutes.
Any thoughts?
Thanks
compfreak is offline   Reply With Quote
Old 05-31-2009, 01:42 AM   #2 (permalink)
PaintedHubCaps
View inhakinseattle's Photo Gallery
hey~ same here...i thought it was just me. but guess not doesn't smell when its on the hot setting but always the cold....
inhakinseattle is offline   Reply With Quote
Old 05-31-2009, 09:09 AM   #3 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
1. Check your cabin filter.
2. Verify that condensed moisture is draining out under the car.
gdanaher is offline   Reply With Quote
Old 05-31-2009, 01:33 PM   #4 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
Cabin filter, check.
Condensed moisture draining..hmmmm......where?
workerant is online now   Reply With Quote
Old 05-31-2009, 01:56 PM   #5 (permalink)
Maven
gdanaher's Avatar
Where are you located? Earth really dowsn't cut it. Humid or not? Humidity condenses and drains out through the fire wall below evaporator. Let car idle for a few with the a/c on and see if you have water dipping out. If not, and if humid enough to condense moisture on a cold glass of tea, then loo for the drain and unplug it.
Old 05-31-2009, 08:20 PM   #6 (permalink)
SE_2007's Avatar
View SE_2007's Photo Gallery
i have the same issue too, will look into it tomorrow.
SE_2007 is offline   Reply With Quote
Old 05-31-2009, 08:41 PM   #7 (permalink)
View Axxis8203's Photo Gallery
i too have a peculiar smell for the first few minutes after the a/c has been turned off. it reminds me of the masks i am sometimes required to wear at work ( i work in healthcare ). and this has led me to believe that what we're smelling is acutually the air filter media and the chemicals used to treat it.
my drain works just fine...
to further narrow this down i would look into removing the cabin air filter and seeing if the smell is still there.
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
Old 05-31-2009, 09:16 PM   #8 (permalink)
I don't see where is the best accessible place to check... http://www.camrystuff.com/manuals/Ge...nditioning.pdf
Old 05-31-2009, 09:29 PM   #9 (permalink)
it'll be draining on the ground, approximately under the glove box on the passenger side.
Old 06-01-2009, 08:30 AM   #10 (permalink)
Maven
gdanaher's Avatar
Look at page 127 and 149.
Old 06-01-2009, 11:50 AM   #11 (permalink)
no.. those r components. Check page "AC-14". Thats the airway diagram. I am guessing the evaporator grill is where the 'smell' likely to come from. Or the airway itself.
