What should I get at 100k Service 02 camry se. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2009, 04:22 AM   #1 (permalink)
View tkkidd's Photo Gallery
Gen5 What should I get at 100k Service 02 camry se.
I',m not to savy with car maintanance. I do oil chage with good filter and rotate tires and that is it.
Toyota has been good for me, but I think IT can use some TLC before Something goes wrong.
I'm not planning to sell this car at all. I want to see how long it will last~
I appreciate all your info and comments, Thank you for sharing any input.1
My faithful, everlasting camry just passed over 100k.
My mechanic is a family friend and charge really low rate, but he is so damn busy, if i say " 100k miles service, he might not do some other things. ( like some mech will replace water pump because it's gotta go time soon)
The car runs fine except .. catalist coverter light is on.. + white puff of smoke at the start.
I'm changing spark plugs to NGK Iridium IX.
I think I need coolent flish because it's pretty dark...
what else do i need?
Transmission flush?
Brake fluid?
Serapin Belt was replaced at 80k.
Anything else? water filter...pump?
A/C.. is it samething if i charge at auto shop and top it off with from can from home?
Thank you so much!!
tkkidd is offline   Reply With Quote
Old 06-05-2009, 09:51 AM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $968358
iTrader Score: 7 reviews
Is it a V6 or an I4?
If it's a V6 do the timing belt and water pump.
Do a tranmission service for sure.
do a flush and fill on the rad as well...
There is a maintenance schedule in your owners manual, or online too.
2002 Camry SE V6 "Snow White" - She ate the poison apple and is asleep until April.
1998 Subaru Legacy 2.5GT Limited "Grimhilda" - Geared Up For Winter!!!
Old 06-05-2009, 12:41 PM   #3 (permalink)
Gameroom cash: $107200
View mcgill_redmen's Photo Gallery
Also time to change the car battery, maybe stabilizer bushing front & back, brake service, engine wash and more to keep your car in tip top shape.
mcgill_redmen is offline   Reply With Quote
Old 06-05-2009, 04:03 PM   #4 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
replace tranny fluid, antifreeze, oil/filt chg, spk plugs, timing belt if v6.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 06-05-2009, 04:28 PM   #5 (permalink)
2009 Camry SE I4 MGM
glenn14's Avatar
Gameroom cash: $273425
View glenn14's Photo Gallery
If you have either an owners manual or a maintainence book that states what needs to be done at each
maint. interval. I would go by that. I can post up later on what my GEN6 book states.
Here is a good thread on TN. Maintenance @100K : 04 SE, 2.4L
Glenn
2009 TOYOTA CAMRY SE
CUSTOM BLACKED OUT HEADLIGHTS WITH MDX D2S HID RETROFIT, RED PAINTED BRAKE CALIPERS, JBL SOUND SYSTEM,MOON ROOF PKG. H11 WIRE HARNESS, MEGAN FSTB. XENON DEPOT DIGITAL BALLASTS, D2S 5000 BULBS, W.T. FLOOR LINERS
glenn14 is offline   Reply With Quote
Old 06-05-2009, 05:34 PM   #6 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $318510
View gdanaher's Photo Gallery
It needs a good visual inspection.
-check for oil leaks
-check cv boots
-check hydraulic brake components for leakage. Consider flushing
-check brake pad wear
-check light bulbs for function
-check filters
-flush and replace nasty coolant
-flush transmission
-check pvc valve for function
-pull valve cover and check for sludging
-replace belts if showing wear
-replace coolant and heater hoses if aging
gdanaher is offline   Reply With Quote
Old 06-05-2009, 09:26 PM   #7 (permalink)
Gameroom cash: $498830
View JohnGD's Photo Gallery
Others' advice are great. I'd drop the ATF pan and change out the strainer as well. Fram ATF kit works well like $15-20.
The concern is with the "white smoke" at start up. This should be white smoke with a bluish tint, which we call "blue smoke". This means your valve stem seals are leaking and could use replacing while doing a timing job.
White smoke may indicate coolant leak into cylinders (head gasket or cracked engine block), neither is good news. So look at the smoke color again. Are you using coolant? I hope not. Black coolant is not good news. Coolants don't turn black when they get old, not that I know of.
So focus on the integrity of the head gasket first. After you rule that out, change out the maintenance parts including the radiator hoses. I'd recommend Gates belts and hoses from your local NAPA store. NGK Iridium-IX is great stuff. Good pick. Love them.
Transmission flush?
Brake fluid?
Thank you so much!!
Old 06-05-2009, 09:27 PM   #8 (permalink)
Typical timing belt job (3SFE, 5SFE):
GATES TCK199 (kit of timing belt with two pulleys and instruction) $84.79
GATES Part # K030295 PS belt $4.32
GATES Part # K050435 Alt/AC $12.12
FEL-PRO TCS45641 Cam seal $4.11
FEL-PRO TCS45920 Crank seal $6.04
BCA Part # 221820 Oil pump seal $2.71
AISIN (Toyota #16110-79185) water pump $58.79
your local NAPA store has Airtex water pump
FEL-PRO VS50304R valve cover gasket set $13.94
Old 06-07-2009, 05:17 AM   #9 (permalink)
Deadly Sushi's Avatar
View Deadly Sushi's Photo Gallery
Gen 5 has a timing chain not a timing belt from what I understand.
1992 Camry I-4 with 145K miles
Deadly Sushi is offline   Reply With Quote
