gen 5 headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2004, 03:43 PM   #1 (permalink)
DIYer
View italia490's Photo Gallery
Question gen 5 headlights
I have seen some threads about taking the orange plastic out from inside the headlights. Does anyone know that easiest way to seperate the plastic lens from the housing? Like I said there is a thread about this, but it does not say how the lens was seperated from the housing.
02 Camry SE
Injen intake
17" Exel rims
Tein S Tech lowering springs
Painted brake calipers
Custom exhaust
Sportivo grille
italia490 is offline   Reply With Quote
Old 02-04-2004, 05:17 PM   #2 (permalink)
Prepare tortilla chips.
Daffunda's Avatar
View Daffunda's Photo Gallery
There is no easy way. It is glued together. Take a razor and cut along the seal, or put it in the oven.
The reason why I don't like doing this to mine is
1. You might break somethin.
2. If you do this on a semi humid day, then you will be sealing in moisture, and will have condensation inside the headlamp after you assemble it and use it.
Daffunda is offline   Reply With Quote
Old 02-04-2004, 05:45 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
try this;
http://www.toyotanation.com/showthre...ight=projector
TN Map - Add Yourself
Phi is offline   Reply With Quote
