02 Toyota Camry Se Navigation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2009, 07:54 PM   #1 (permalink)
Marcanegocio's Avatar
View Marcanegocio's Photo Gallery
Gen5 02 Toyota Camry Se Navigation
I've recently purchased a 2002 Toyota Camry SE. The car has a stock radio and off from ebay i purchased the factory navigation from a 2002 toyota camry SE. The unit arrived, but it doesn't come with the plugs. I went to the toyota auto parts and they said i would either have to purchase the whole hardness with the plugs and it would come really expensive. I just need the radio to play cd's, i don't really care that much about the nav. What do u guys recommend? and where would i be able to get the plugs and if you guys think it would work?
Marcanegocio is offline   Reply With Quote
Old 06-15-2009, 08:04 PM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
what plugs? Take the wire harnesses that are in your current stock radio and plug them into the new one..
MrSo0h0o is offline   Reply With Quote
Old 06-15-2009, 08:08 PM   #3 (permalink)
I already took it apart but the hardness don't match and it has alot of plugs i don't even know which one is the correct one. This is what the unit I got looks like.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 06-15-2009, 08:17 PM   #4 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
thats the problem right there... the nav head unit is a JBL head unit and your stock head unit is non-JBL. You lack the necessary amplifier and associated harnesses to use the JBL unit in your car.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 06-15-2009, 08:24 PM   #5 (permalink)
KZ
kazakh's Avatar
Gameroom cash: $222450
View kazakh's Photo Gallery
Check oemvalue.com for info
http://i210.photobucket.com/albums/bb69/kazakhshal/IMG_1164-3.jpg
kazakh is offline   Reply With Quote
Old 06-15-2009, 08:25 PM   #6 (permalink)
MrSo0h0o's Avatar
i thought the SE's came stock with the JBL system? I guess not?
Old 06-15-2009, 08:39 PM   #7 (permalink)
The Toyota Guru
Timbits93's Avatar
Gameroom cash: $248652
View Timbits93's Photo Gallery
In Canada, the 2002 Camry SE came with JBL as Standard
Timbits93 is offline   Reply With Quote
Old 06-15-2009, 08:46 PM   #8 (permalink)
What do I do??
So what do u think i should do in regards of installing this navigation unit??
Old 06-15-2009, 08:50 PM   #9 (permalink)
MrSo0h0o's Avatar
well, if you are sure you do not have the correct wire harness, aka do not have the JBL package, just se if u can return it. If not, sell it and try to recoupe what you paid. It is not worth it otherwise
Old 06-15-2009, 08:54 PM   #10 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
I love these stories.....................
Old 06-16-2009, 03:25 PM   #11 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
in order for the unit to turn on you will need to use the memory wire, power wire and ground, and you are using 6 speaker, that mean wire the 6 output speaker wires to your speaker.
that should work right??? slipt the wire directly from the unit to the factory harness
LoudCamry is offline   Reply With Quote
Old 06-16-2009, 03:41 PM   #12 (permalink)
I think that should work am just confused am going to look over where i could find the adapters with the wires that come out from the unit. am so stress i want to install it as soon as i can if possible.
Old 06-16-2009, 04:55 PM   #13 (permalink)
MrSo0h0o's Avatar
usually there arent any harnesses that come out of the unit. its not like an aftermarket headunit where you spice together wires. This unit was made so that you plug the wire harnesses directly from the car into the unit.
Old 07-31-2009, 03:21 PM   #14 (permalink)
Thanx to your advice i was able to installed the unit. I was able to get the plug and adapter from a link you provided me. I contacted the person and paid with paypal.
