Creaking from front end - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2009, 07:33 PM   #1 (permalink)
blu ribbon 07 SE V6
View rbeleno's Photo Gallery
I have a 07 Camry SE V6. For the last 2 months I've had a creak develop in the front end. It occurs for example during acceleration when the front end raises slight or when going over slower bumps... it seems to be directly connected to the "flexing" of the frame? in the front.
Now I've already searched and did not find neone with a similar complaint/symptom. Can any one advise? My feeling is it might be the sports bar that goes across the top of the suspension?
2007 Metallic Blue Camry SE V6, black leather, 5%tint, dual fact. mufflers, factory jbl, pioneer 12"sub w/1000w amp, VSC/TC,ABS,EBD,4disc 17"fact., 10kHID's
Cardomain: http://www.cardomain.com/ride/718358
rbeleno is offline   Reply With Quote
Old 06-20-2009, 07:35 PM   #2 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
did you get alignment right before it started creaking?
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 06-21-2009, 04:20 AM   #3 (permalink)
blu ribbon 07 SE V6
no -- actually it started creaking one day when i was backed into...it was very minor at 1st now its always... very light minor hit no damage -- less than 5mph. It was/is creaking pre-and-post alignment. I had some front end work done due to a fender bender (strut, LCA, knuckle).
Old 06-21-2009, 08:17 PM   #4 (permalink)
View TOYO-ED's Photo Gallery
i got a similar issue too. I got a 09 SE 4-Cyl. But i suspect it has to do with the suspension; It may have to do with the springs rubbing against something. I hear it when i get out of the car sometimes.
TOYO-ED is offline   Reply With Quote
Old 06-21-2009, 10:47 PM   #5 (permalink)
blu ribbon 07 SE V6
Ahh Ha!
I figured it out! Its IS my strut bar. Its cracked! But the crack is located on the passenger side near the strut...the bar hides underneath the plastic for the vents... I lifted the plastic off and i saw the 4-5 inch crack... How does this happen? I'll get progressive to cover/replace it under the front end damage the car had. I did not have any frame damage (so they told me) is this a sign that more damage might be present? everything seems to line up right... After i replace it... can i put an aftermarket bar on it too? or do i have to remove the factory...... u might want to look under ur hood (SE-ers) if u want a better grasp... I found the creak b/c i applied pressure with my hand on the strut bar and was able to replicate the sound. Quieter camry days are ahead!!!
