camry 08 bad rear shocks? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2009, 12:25 AM   #1 (permalink)
View ylen13's Photo Gallery
I own camry 08 se v6 with 17300k miles it feels like my rear shocks need to be replaced. You can hear and feel it on any road that is not in very good condition. Please tell me that it's not normal for shocks to go bad on camry after only 17k
ylen13 is offline   Reply With Quote
Old 06-21-2009, 12:28 AM   #2 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
It might be just your bushings on the control arm. I had the same problem with mine. Bring it to the dealer and have them check it out.
Redline_Me is offline   Reply With Quote
Old 06-21-2009, 04:22 AM   #3 (permalink)
blu ribbon 07 SE V6
View rbeleno's Photo Gallery
Hey buddy... what are your symptoms? I had another post about noise (thumping) coming from the rear... is this similar to urs?
2007 Metallic Blue Camry SE V6, black leather, 5%tint, dual fact. mufflers, factory jbl, pioneer 12"sub w/1000w amp, VSC/TC,ABS,EBD,4disc 17"fact., 10kHID's
Cardomain: http://www.cardomain.com/ride/718358
rbeleno is offline   Reply With Quote
Old 06-22-2009, 08:51 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Toyota had mount problems with Gen4 in the front and rear mount problems with Gen5. TSBs and free replacements of mounts. You would think by Gen6 rear mount problems were fixed? These struts should last at least 30-50K miles without losing too much damping.
Well, Camry's quality has been slowing going down over the years. I wonder if your engine has the same head bolt failure potential. So a worn shock or bad mount is probably the least of your worries. But take it back for warranty replacement.
http://www.enginebuildermag.com/Arti...e_engines.aspx
Old 06-24-2009, 12:39 AM   #5 (permalink)
Yes it's similar. You can basically feel every bump. I am taking car in tomorrow will post update on what is wrong.
Old 06-24-2009, 09:12 AM   #6 (permalink)
blu ribbon 07 SE V6
also...
someone else (here) told me that the car has 6 bushing locations... 2 front, 2 middle and 2 rear. I have not verified this info...since i have not gotten my car repaired yet, but this might be the source of ur issue. good luck and yes, please let us know the outcome. Thanks!
Old 06-24-2009, 02:25 PM   #7 (permalink)
Update:Took car to dealer and they didn't find anything wrong They said my right ream is damaged(if it was, i would feel vibration during all the time, i don't). They adviced to get balance/alignment done. I got that checked and it's perfect. So basically this dealer was to lazy to look for problem i am gessing. Will take it to different dealer in next couple of days.
Old 06-24-2009, 03:42 PM   #8 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
Which dealer did you go to? They lied to you?
GT-R is online now   Reply With Quote
Old 06-24-2009, 05:10 PM   #9 (permalink)
Yes i am seeing that pattern. northridge toyota
Old 06-24-2009, 05:24 PM   #10 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
The dealers go by the Shock TSB for replacement guideline.
Old 06-26-2009, 01:32 AM   #11 (permalink)
Well, if the struts weren't doing this before and started to feel like they're going bad, then they probably are. You can call the Toyota hotline and explain this to them. Maybe they can better help.
Old 06-26-2009, 06:03 PM   #12 (permalink)
blu ribbon 07 SE V6
forgive my ignorance.... Toyota hotline?
