steering wheel vibration on freeway - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2009, 04:39 AM   #1 (permalink)
07SEV6
View lklee's Photo Gallery
Gen6 steering wheel vibration on freeway
recently I noticed that driving over 80 mph on a smooth freeway produces a vibration on the steering wheel. Should I have it checked out?
lklee is offline   Reply With Quote
Old 06-25-2009, 08:25 AM   #2 (permalink)
Camry Owner
View MEGADETHFAN's Photo Gallery
I had that on my car after the dealer rotated the tires. They tried to balance them but to no avail. I then went to Discount tire and they did the job right.
A good balancing job should resolve the vibration
MEGADETHFAN is offline   Reply With Quote
Old 06-25-2009, 08:36 AM   #3 (permalink)
pedron
Guest
Posts: n/a
View pedron's Photo Gallery
I don't know about you, but the posted maximum speed allowed in my state is 65MPH. I would suggest simply slowing down.
Old 06-25-2009, 09:07 AM   #4 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
the vibration still will happen at about 65. get a alignment done on the car and enjoy.
WrongFitmentCrew#628
Old 06-25-2009, 09:16 AM   #5 (permalink)
Stewiefied Racing CEO
leinadneon's Avatar
View leinadneon's Photo Gallery
i believe theres a few threads about this ....idk my car still does it tho
^^^^^^^^^^RIP^^^^^^^^^^^
www.cardomain.com/id/leinadneon
leinadneon is offline   Reply With Quote
Old 06-25-2009, 09:57 AM   #6 (permalink)
Camry Owner
Some counties in Texas have an 80 MPH speed limit.
The balancing could be off as well, when my car's steering wheel was vibrating it was due to improper balancing
Old 06-25-2009, 11:43 AM   #7 (permalink)
Gameroom cash: $303755
Like MEGADETHFAN said originally, most likley you tires are out of balance. It's not uncommon to loose a wheel weight and throw the balancing off.
Mike
Mike Gerber is online now   Reply With Quote
Old 06-25-2009, 09:02 PM   #8 (permalink)
Paul_09WhiteV6
now that i really could think..... if u let go of steering wheel at regular to higher(max 60) and it goes one way or other then u need alignment. if u go over 60 and the car vibrates then ur off balance. rebalance all wheels.
Old 06-26-2009, 11:22 AM   #9 (permalink)
View 2KGTS's Photo Gallery
Double-check inflation pressures first.
2KGTS is offline   Reply With Quote
Old 06-26-2009, 11:32 AM   #10 (permalink)
Portholes are the Sh!t
CheeseHead91182's Avatar
View CheeseHead91182's Photo Gallery
I got my vibration issue solved (almost a year later) I had got after market rims on my Cam so I don't know if it will apply here but the I guess when they put the rims on they forgot to put something called a wheel spacers on one of the rims. Since then my vibration is gone.
CheeseHead91182 is offline   Reply With Quote
Old 06-26-2009, 04:08 PM   #11 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
It's called Hub-Centric Ring.
Old 07-06-2009, 04:24 PM   #12 (permalink)
View slaulau's Photo Gallery
I experienced the same problem and my car is still under warranty. They have a TSB for that and I got a new front brakes done.
slaulau is offline   Reply With Quote
