Removing/Painting the rear Toyota emblem.. how did you do it? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2009, 09:45 PM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
hey guys I wanna paint my rear Toyota emblem a black/black pearl color.. I remember some people saying to remove the rear emblem you have to release it from inside the trunk. I was wondering how others have done it. Remove the emblem and paint it? Mask it off and paint it while still on the car?
MrSo0h0o is offline   Reply With Quote
Old 06-28-2009, 09:48 PM   #2 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
remove it just like debadging your car. but when you remove it, the adhesive will be pretty much shot.
your best bet would be to buy a new one, paint it, remove old emblem and replace with the new one.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 06-28-2009, 09:50 PM   #3 (permalink)
MrSo0h0o's Avatar
I thought the toyota emblem was held in by clips? or is it just 3m tape? I have no problem with putting new 3m tape on, i did it with my TRD emblem that is on my grille now.
Old 06-28-2009, 10:03 PM   #4 (permalink)
MrSo0h0o's Avatar
Originally Posted by djkor View Post
The rear Toyota emblem is held in by adhesive. It has a couple of pins in it to help get the alignment spot on and that's about it. When I took mine off, I found that new adhesive tape didn't feel as secure. This was due to the shape of the emblem on the back side. I just used black automotive silicone. It's going nowhere now.
thanks djkor i will get at this tomorrow
Old 06-28-2009, 11:04 PM   #5 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
i just shoved a screw driver under and pried it off lol No scratches either!
2002 Camry SE V6 "Snow White"
Old 06-29-2009, 05:17 AM   #6 (permalink)
Attack bird on duty
MaxxHavoc's Avatar
View MaxxHavoc's Photo Gallery
Here is a DIY that I made up at another site (9thgen corolla dot com) that should help you out. It sounds like the rear badge is the same as the one on the corolla. The DIY is also for the other badges, but the center rear Toyota emblem is also covered... Enjoy
This is a very simple DIY but for those like me that like all the details and pictures here you go...
This is basically the same thing as removing the side moldings so some of the pics will be the same as that DIY.
First start off by washing your car good then gather the stuff you'll need.
1. Fishing line or dental floss work well.
2. A hair dryer to heat things up if necessary. I didn't need it, but you might if your emblems are being difficult.
3. Goo Gone or something similar to remove the adhesive residue.
Get your dental floss or fishing line and start at one end using a sawing motion with light pressure. Slowly work your way across the emblem until it comes off.
It's as simple as that. Continue on taking off the emblems you want removed.
The next few pics instructions are for the rear center emblem. Not everyone will want to take this one off so skip past it if you want. I removed mine because I wanted to paint it and put a piece of carbon fiber behind it so that I could break up the color a bit.
The rear center emblem was a little more tricky. You don't want to go down to far with your dental floss/fishing line. In the pic below you can see where I stopped. You don't want to try and go any farther than that because you will just run into one of the prongs on the back of the emblem that will stop you anyway. And you also take the chance of cutting into the paint on the side of the emblem if you go to far because the area around the emblem starts to come out farther than the emblem and if you go to far your dental floss/fishing line will cut into the paint.
After you have cut through the adhesive to the point in the above pic you will need to use both hands and slowly pull the top of the emblem away from the trunk. Use your fingernails at first and pry it away. You will see it start to separate from the adhesive below where you used the dental floss/fishing line. Don't rush it, let the adhesive slowly break away as you pull and you'll be done. In the pic below I was only using one hand because the other had to take the picture
In the pic below you can see where the holes are that the prongs from the emblem sit in. I didn't have much residue from the adhesive from this emblem. But if you do the next step below is what to do for that.
Same basic thing for getting rid of the excess adhesive as the side moldings. I didn't take a picture of it when I did the rear emblems so here's a pic of how I did it on the side moldings. I just rolled the excess off with my thumb.
Then take your Goo Gone or similar stuff and remove the rest of the residue. Wash again in the areas you were working. Wax it up and your done.
Personalise yours how you want. I took all of mine off because I wanted to do some painting. I've seen all kinds of variations as far as what to take off. What to change etc...
I've changed my rear emblems several times but this is what I have now.
My car was dirty and it just finished raining but this is how it looks today.
For reapplying any emblems etc you can find some double sided molding tape at most auto stores. I didn't care for the stuff I found at the auto parts store. So I went looking on ebay and found some 4"X6" sheets of 3M OEM double sided molding tape. There wasn't alot of it listed but I'm sure it shows up pretty regularly.
MaxxHavoc is offline   Reply With Quote
Old 06-29-2009, 05:31 PM   #7 (permalink)
MrSo0h0o's Avatar
Here are my results guys.. didnt get to put it back on the car yet because I still need to reapply the 3m tape:
Old 06-29-2009, 05:42 PM   #8 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
Very nice! Now do mine!
CarDomain
Old 06-29-2009, 05:45 PM   #9 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
Hmm.. Nice one Soo Hoo!
GT-R is online now   Reply With Quote
Old 06-29-2009, 07:34 PM   #10 (permalink)
Gameroom cash: $101950
iTrader Score: 6 reviews
View salvimoreno's Photo Gallery
Looks good, what paint did you use?
salvimoreno is offline   Reply With Quote
Old 06-29-2009, 09:03 PM   #11 (permalink)
ebumdude's Avatar
looks decent for a spray can.
-09' Venza
Old 06-29-2009, 09:16 PM   #12 (permalink)
Looks good man!
Old 06-29-2009, 09:40 PM   #13 (permalink)
MrSo0h0o's Avatar
I used duplicolor magnetic gray.. It looks like it could be an OEM match for the gen 6 mag gray
Old 06-29-2009, 10:06 PM   #14 (permalink)
must.resist.modding
bandit's Avatar
If you havent put it on yet, we can find out how it will look on mine
CarDomain
Old 06-29-2009, 11:16 PM   #15 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
hmm maybe i should do black chrome... anyone feel like making me one
WrongFitmentCrew#628
