Coolant Drain Plug Jammed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2009, 01:38 AM   #1 (permalink)
View horspowr1001's Photo Gallery
Gen5 Coolant Drain Plug Jammed
Hey all,
I have a 98 Camry with the 1MZ-FE V6 engine, 156K miles. Today I decided I'd change the timing belt and water pump. I also figured I'd drain and flush the cooling system while I was at it.
I drained the coolant from the radiator as well as the block drain plug closest to the front of the car, which all went fine and dandy. The problem came in when I was working on the drain plug on the opposite side of the block near the firewall.
So I loosened it maybe 3 or 4 turns and it stopped turning, so I figured it was one of those valves with a stop when it's fully open, like a valve for your garden hose connection. Okay, that's fine, I said. After the coolant had drained from the drain tube that's adjacent to the drain plug bolt, I tried screwing the bolt back in, which is where everything went to hell.
The bolt turned maybe 1/8th of a turn and stopped. Now normally, this would indicate cross-threading. However, I didn't completely remove this bolt, so I found it really odd that it wouldn't find its threads again.
So I turned it a bit harder, thinking that it had gotten caught on some dirt that may have settled on the threads inside the valve. No dice. So I loosened it again and started wiggling it as I turned it in, hoping it would find the correct threads. Still only the 1/8th of a turn. Tried the same thing a few times more to no avail. I could also feel the bolt starting to round a bit.
So I tried just barely heating up the area around it with an oxy-act torch, and then turning it in carefully. Nothing. I tried more backing out and turning it in, and still no dice.
So I'm stuck with an open coolant drain plug, which you can see from the pictures below, is now pretty damn rounded. I've only come up with a few solutions so far:
1) Attach a small rubber hose to the end of the drain tube and plug it with a brass fitting on the other end and hope the hose clamps keep it there.
2) Drill and fit another bolt inside the current one or cut a new hexagonal bolt head pattern, then heat it up even more, and then try tightening it.
3) Replace the part.
Now the issue with #3 is that the valve is actually part of what appears to be a larger single-casted piece that seems to have multiple functions. I say this because above the drain plug, there's a connection for a ribbed metal line that feeds into the exhaust manifold (See pictures).
I originally thought this was part of the PCV or EGR system, but I couldn't find anything in my Haynes manual that showed this connection to the block. So I even if I wanted to replace it, I have no idea what this mystery part is called.
Does anyone have more ideas or know what this part is?
Overall shot for orientation:
http://img189.imageshack.us/img189/4...9550edited.jpg
Close-up:
http://img216.imageshack.us/img216/8...9551edited.jpg
horspowr1001 is offline   Reply With Quote
The Following User Says Thank You to horspowr1001 For This Useful Post:
fenixus (04-02-2011)
Old 07-09-2009, 06:40 AM   #2 (permalink)
Gameroom cash: $303755
Your 98 is a generation 4. You would be better served moving this thread to the generation 3 and 4 section, where more people with experience with those cars would read your post.
Mike
Mike Gerber is online now   Reply With Quote
Old 07-09-2009, 07:47 AM   #3 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
It's time to at least visit the dealer service with the pictures with a plan on having the car towed in to see if they can fix it. I don't know if removing that plug was going to do more than just opening the pet on the radiator, but it's done now. There might be a spring and ball bearing or some other sort of valve in behind that bolt, so you need to find out before you put the torch to it again.
gdanaher is offline   Reply With Quote
Old 07-09-2009, 08:59 AM   #4 (permalink)
"Circle of trust"
View catric69's Photo Gallery
The mystery part seems to be part of the emission system = EGR cooler. Good luck with you repairs.
catric69 is offline   Reply With Quote
Old 07-09-2009, 11:09 AM   #5 (permalink)
Sorry about the incorrect forum folks, I went by Wikipedia's generation number.
Old 07-09-2009, 11:30 AM   #6 (permalink)
Maven
gdanaher's Avatar
Just hope you can fix the problem. This really is specific to any particular year.
Old 04-02-2011, 07:43 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
thanks a ton for a picture of rear block drain plug. you don't even know how much it helped me. I had a hard time locating it when draining all coolant (vc gasket job, new thermostat, new ect sensor, etc..) ... was looking at wrong spot .... if I haven't found that picture I would abandon draining the rear block thanks a ton bro!
Originally Posted by horspowr1001 View Post
Old 04-03-2011, 02:16 PM   #8 (permalink)
No problems, that's what this site is for right? Just be careful with that plug, I'm sure you read my story. It ended with me just forcing the rest of it out, destroying the threads on the bolt and partially of my block. I had to clean the metal out, get a rare tap size (expensive), a new plug from Toyota (also expensive-$18), and re-thread my block. Quite a hair pulling experience indeed...
Old 04-03-2011, 02:43 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
ouch, that's bad experience. I hate when such bolts brake or strip in crazy locations like that ... plus it immobilizes the car for time being ... very stressful ... and annoying like hell...
I was lucky then. Mine was sitting very lightly in there. FSM specs call for only 61in-lbs (or around 5ft-lbs) torque, so little almost like finger tight
I used torque wrench on tightening it down, probably went above 5ft-lbs, but it's good anyways, nothing broke.
