If you do that, it'll take a while before you get all the old coolant out. I think if you drain the radiator, you get about 1 gallon or less out and the cooling system capacity is 7 to 8 quarts. So if you do one drain and refill the radiator only (assuming you have 50/50 mix to start) the coolant will be ~25%, then ~12.5%, then ~6.25%, etc. It'll be faster if you drain both the block and radiator, but I don't know how much fluid is contained in the block and radiator combined since some of that fluid is in the heater core also.
So after do the drain and refill of the block and radiator with distilled water twice, I would assume that percentage of coolant is fairly low -- less than 5%. At this point, I would just pour in the proper amount of coolant, approx 3.5 to 4 quarts for 50/50 and then pour in the water the rest of the way. Just remember to set the heater to high and to ensure that the thermostat opens up when you're running the distilled water.
If you want to use Toyota pink coolant and your car has pink coolant already, don't put any distilled water since you can only buy that coolant as 50/50 mix. Just drain the block and radiator, refill, and you're done.
2007 Camry 2.4L 5M
