Smog related question...swapped engine 06 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2009, 02:02 AM   #1 (permalink)
chugs's Avatar
View chugs's Photo Gallery
Gen5 Smog related question...swapped engine 06 camry
I swapped engines on my 06 camry with another 2azfe. Old engine had cracked bottom block. Installed engine came out of a 05 scion tc, CA engine. I have not had issues at all, except I should've replaced the tq converter seal. It's leaking a little. Anyways, for the upcoming smog inspetion, I'm sure it will pass. What I would like to know is, will I have any issues with the smog inspector failing me for not having the original engine or will it not even matter as long as it passes the smog inspection? Will there be any issues or problems when I go smog it? Links to smog laws would help out as well. Thanks.
HAVE A NICE DAY!
chugs is offline   Reply With Quote
Old 07-19-2009, 07:05 AM   #2 (permalink)
chugs's Avatar
bump
HAVE A NICE DAY!
Old 07-20-2009, 07:15 PM   #3 (permalink)
chugs's Avatar
bump
HAVE A NICE DAY!
Old 07-22-2009, 08:52 PM   #4 (permalink)
chugs's Avatar
bump for no replies....?
HAVE A NICE DAY!
Old 07-22-2009, 09:20 PM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
Probably no one knows. I think I recall reading that the engine is supposed to be the same year or newer and that all the smog related equipment is supposed to be transferred from the donor car also. I'm not certain though as I've not done an engine swap.
2007 Camry 2.4L 5M
Old 07-23-2009, 02:43 AM   #6 (permalink)
chugs's Avatar
thanks for the reply, i will have to keep on looking for info
HAVE A NICE DAY!
Old 07-23-2009, 08:03 AM   #7 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $318510
View gdanaher's Photo Gallery
Why don't you just ask the guys who do the tests?
gdanaher is offline   Reply With Quote
Old 07-24-2009, 09:24 PM   #8 (permalink)
chugs's Avatar
I was going to do that next.
HAVE A NICE DAY!
Old 07-25-2009, 03:33 AM   #9 (permalink)
I Miss my I4VVTI
iTrader Score: 6 reviews
View gene112601's Photo Gallery
usually smog test shop they dont care about if ur engine swaped or fixed if the visual is like stock engine u will be fine since ur engine is same spec as before they never will check the engine VIN # everything will be fine just dont ask first wait if someting goes wrong.. if fail the smog he will ask you after just stay back and watch what hes doing if u pass ur good to go ifs not try to find another way good luck!
*remember just go to the shop like normal test dont ask or talk nothing about to swap
gene112601 is offline   Reply With Quote
Old 07-26-2009, 01:36 AM   #10 (permalink)
chugs's Avatar
That is exactly what I was going to do. I'm not going to mention anything. Just let the smog tech do what he does and I'm just gonna stand back and watch.
HAVE A NICE DAY!
Old 07-26-2009, 02:51 AM   #11 (permalink)
I Miss my I4VVTI
k bro u will pass that test for sure ifs not let me know i got hook-ups
Old 07-26-2009, 03:50 AM   #12 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
Yeah your replacement engine is the same as your old one, it's also still running all the original pollution gear. There shouldn't be any problem at all.
The only concern is you now have a different engine number, depending on how vehicle registration works in your area you may need to notify the registration body about the change of engine number.
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
Old 07-29-2009, 07:44 AM   #13 (permalink)
chugs's Avatar
I will have to look into that. Thanks.
HAVE A NICE DAY!
