The dealer suggests a 30k mile checkup...I did not get the 25k or the 30 k i am at 27k miles right now, here is what they include and the 30k alone is $258....is it worth it? Should I just get an alignment or is all this necessary at 27k?
2007 Camry
25,000 Miles - 30 Months
<< BACK -
INTERVALS -
NEXT >>
Replace engine oil and oil filter 1
Rotate tires
Visually inspect brake linings/drums and brake pads/discs
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Tighten nuts and bolts on chassis
Driving on Dirt Roads or Dusty Roads
Inspect ball joints and dust covers
Inspect drive shaft boots
Inspect engine air filter
Inspect steering linkage and boots
Applicable Footnotes: 1) Reset the oil replacement reminder ("MAINT REQD") light after replacing engine oil.
2007 Camry
30,000 Miles - 36 Months
<< BACK -
INTERVALS -
NEXT >>
Rotate tires
Replace cabin air filter
Replace engine air filter Inspect the following:
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs 3
Drive shaft boots
Engine coolant 4
Exhaust pipes and mountings
Front differential oil
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Radiator, condenser and/or intercooler
Steering gear box
Steering linkage and boots
Transmission fluid or oil
An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps!
