2002 Evap Code P0446 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2009, 06:11 PM   #1 (permalink)
View galion42's Photo Gallery
I have just purchased a 2002 Camry LE for my wife. I purchased from a friend at work. Had 72,000 miles and loaded. I had a overheating problem, which was fixed by replacing it. New problem was a Evap Code P0446. Note to all when call a dealer they will tell you that the replacement of the canister will fix this problem at a part cost of 270.00 . All that needed replaced was a Vacuum, Valve back by the canister Part No. 90910-12264. Whatever the reason in the database it calls to replace the whole canister because the valve is not seperate. Well total cost of project was 162.00 with part and labor which is a pain.
galion42 is offline   Reply With Quote
