Checking how much Brake Pad remains? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2009, 06:43 PM   #1 (permalink)
icqboy51's Avatar
View icqboy51's Photo Gallery
Gen5 please delete
thanks for the help guys!
[Gen5 - DIY] Footwell CCFL
http://www.toyotanation.com/forum/signaturepics/sigpic169867_1.gif
icqboy51 is offline   Reply With Quote
Old 08-03-2009, 07:18 PM   #2 (permalink)
pedron
Guest
Posts: n/a
View pedron's Photo Gallery
It's easiest to check with the wheel removed. Either that or get underneath the car with a shop light. Might as well remove the wheels.
Old 08-03-2009, 07:34 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Originally Posted by icqboy51 View Post
is it possible to check how much is left without taking the wheel off?
Not accurately....you need to measure the thickness of both the inside and outside pads.
Old 08-03-2009, 10:04 PM   #4 (permalink)
CamrYmproving,
davidsondude5196's Avatar
View davidsondude5196's Photo Gallery
Just buy new ones when you feel they are starting to wear off. When you press the break and feel them shaky or as if "they aren't gripping as before" then you should replace them. They are pretty cheap
davidsondude5196 is offline   Reply With Quote
Old 08-03-2009, 10:24 PM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
Wow, this is just more auto voodoo. The pads should work and feel just fine right down to the point that metal hits metal, and then it is largely too late for the rotor.
If in doubt, jack the front of the car, put it on stands, pull both wheels and give it a look on both inside and outside on both calipers. Sometimes a caliper will hang a little and one pad will wear faster than the other. Also you should have a new set handy for two reasons. One, if they are in fact worn too thin you will have them to swap out and half the work is already done. Secondly, without knowledge of the actual thickness of a new pad you really have nothing to compare the old one to if it say is worn 50 percent. Common sense may not be common today, but do try anyway.
gdanaher is offline   Reply With Quote
Old 08-03-2009, 10:56 PM   #6 (permalink)
'07 XLE
Gen6
BS.
Old 08-05-2009, 03:00 PM   #7 (permalink)
icqboy51's Avatar
so all i need to remove are the wheels? then the thickness of the brake pads should be visible for inspecting?
and no further removing of any parts needed right (ie, caliper)?
Old 08-05-2009, 05:30 PM   #8 (permalink)
Maven
gdanaher's Avatar
Right, unless you need to pull the caliper off to replace the pads. It will be obvious to you once the wheel is off.
Old 08-05-2009, 05:32 PM   #9 (permalink)
pedron
Guest
Posts: n/a
correct.
Old 08-05-2009, 05:34 PM   #10 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
to make things easier, once your car is up on jack stands, turn the wheel either left or right, so you can see the pads without having to stick your head into the wheel well
MrSo0h0o is offline   Reply With Quote
Old 08-06-2009, 05:30 PM   #11 (permalink)
icqboy51's Avatar
if some 1 could give me some advice thanks1
