Long term car storage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2009, 07:16 PM   #1 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
Lightbulb Long term car storage
I have not posted much lately, life is very busy again. As some of you might remember, I bought my Camry when I came back from working in Asia. I am now seriously considering to go back for some more years- too many good chances their I can't pass up.
I am planning to keep my house and Camry in Florida - kind of summer residence for the family to get a break from busy life in Asia.
Now to my question: How would you store the car - I want to be able to drive it when I come for vacation w/o having to go through a lot of hassle. Possible? The car will be in the garage, no frost, no really cold weather.
So, what are your recommendations? I hope not to drain any fluids....
PS: If it is too cumbersome, I might just sell it - but don't like the idea.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 08-03-2009, 07:20 PM   #2 (permalink)
pedron
Guest
Posts: n/a
View pedron's Photo Gallery
sell it, that or drain the fluids, place it on jack stands and cover the garage floor with a vapor barrier.
Old 08-03-2009, 07:31 PM   #3 (permalink)
Take it easy... :-)
Tobeit's Avatar
Thx, I get the reason for draining and putting it up on jacks (just don't like it) ..but why putting a vapor barrier on the floor? I have a closed garage with concrete floor?
Old 08-03-2009, 07:45 PM   #4 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
don't put the parking brake on.........i made that mistake, i just got home from a week in Cali, and i left it on and now it's stuck....ugh!
2002 Camry SE V6 "Snow White"
Old 08-03-2009, 07:50 PM   #5 (permalink)
-Kenny-
Guest
Posts: n/a
View -Kenny-'s Photo Gallery
i think u should part out the car n sell it since u wont be here that much, idk just my opinion
Old 08-03-2009, 07:54 PM   #6 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
Sell it.. and.. what is that thing that's like renting the car? This way the car don't need maintenance or other stuff.
workerant is offline   Reply With Quote
Old 08-03-2009, 07:54 PM   #7 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
I'd say don't keep it on jack stands, just inflate the tires to around 40psi or so, keep the exhaust holes covered with a sock or something (Make sure to leave a sticky note so you remember to uncover them), and just leave all windows closed and do not engage parking brake.
Have someone start it every now and then, starting it and driving it around the block for 10 minutes at least once or twice a month will do great.
Otherwise, just do oil changes and fluid level checks everything you come back to drive it.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 08-03-2009, 08:13 PM   #8 (permalink)
Censorship bites!
GeneW1's Avatar
Gameroom cash: $901935
View GeneW1's Photo Gallery
In addition to the good suggestions of elevating the car on jackstands (to reduce the likelihood of flat spots on the tires) and adding fresh oil each time that your store it consider these ideas...
1. Put "Stabile" in the gas tank. This substance is used to reduce aging in gasoline and diesel fuel. Do this before you intend to store it and drive it about to let it get into the fuel system.
http://www.parkeryamaha.com/fuelconditionerqanda.aspx
If you can find any you can add BHT to the gasoline. This will accomplish roughly the same effect. I'd guess a few grams per gallon of gasoline in the tank will do the job.
You car automatically works to make the fuel system air tight, even "testing" it from time to time. It's probably water tight too.
2. Remove the battery, place it on a non-conductive and dry surface, and consider putting a solar trickle charger on it. Do not put it in the sun. The charger will use what ambient light is around to keep the battery charged. This will also frustrate joy riders if they break into your garage.
3. Provided that your systems are reasonably air tight I wouldn't sweat AT fluids or other lubricants.
4. Make a point of insuring that your car cannot be flood damaged and if it can be flood damaged be sure to get flood insurance for your home and possessions. "Flood Cars" are never ever quite right after their exposure and submersion in water.
Hope that this helps
Gene
GeneW1 is offline   Reply With Quote
Old 08-03-2009, 08:24 PM   #9 (permalink)
pay me and I'll use it for U until you come back. LOL
Old 08-03-2009, 08:26 PM   #10 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $821521
iTrader Score: 16 reviews
View GT-R's Photo Gallery
It's leazzee yo.
GT-R is offline   Reply With Quote
Old 08-03-2009, 08:27 PM   #11 (permalink)
2007 Camry SE V6
Gameroom cash: $133290
View thrawnis's Photo Gallery
If you were just going to be gone for a year, storing it (draining the fluids and putting the car on jackstands) makes sense. I'm not sure how to deal with the battery and whether you should disconnect it and/or use a trickle charger. Also, the tires will likely be useless by the time you get back so you might as well just sell the tires as used before you store it.
But any more than a year and you will be losing quite a bit of value on the car. Sell the car now and get a newer car when you get back..
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is offline   Reply With Quote
Old 08-03-2009, 08:57 PM   #12 (permalink)
Originally Posted by GT-R View Post
It's leazzee yo.
Always drive new car and return when the OP is not here to use it.
Old 08-03-2009, 09:26 PM   #13 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
nothing crazy, its not like the car is gonna fail on you.
dont put it on jack stands though. As stated just overinflate the tires and dont put the ebrake on.
Make sure to FILL the tank up with gas. Also I believe you need to add an additive to the gas. Can't remember, but if you dont the gas ends up deteriorating.
Cover openings such as exhaust and intake.
And just throw a car cover over it.
You should be good.
Oh, throw in 1 or 2 things of baking soda in the cabin of the car (trunk too if you wish)
CamrySExxx is offline   Reply With Quote
Old 08-03-2009, 09:34 PM   #14 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
I agreed that you should sell it. Cars in general are depreciated theirs value everyday. So you just losing money by having it sit in a garage + insurance!!!
Sell it and when you come back... buy the Gen7 V6 SE!!!
Old 08-03-2009, 09:39 PM   #15 (permalink)
I ♥ (.Y.)
GT-R's Avatar
NONONO!!!
Just send it to lammy's house, and we'll beat the hell out of that car while you're gone.
Unless Lammy don't share well with me...
