If one is going, the other two are probably not far behind.
Camry V6 is a low volume production, and the fronts are only made by Denso. Bosch is a manufacturer and a redistributor, which means they also package what they don't make to serve as a
one-stop shop. So just get the cheapest.
However, for the downstream, I'd recommend Bosch Planar sensor. This design is more resistant to contamination. It's just a much superior sensor.
Bosch planar type:
http://www.boschautoparts.com/Produc...nsors/PlanarO2
Originally Posted by 16v100bhp
The bank 1 a/f sensor seems on its way out. The car is a 1999 v6 1MZFE
Since this is the sensor one before the "precat" I assume this is the California standard sensors...
The option of sensors are
- Bosch part# 15217
- Denso #2349009 - Front right
- Denso #2349007 - Front left
Questions
1. Should I go for the denso or the bosch? Any known issues with either?
2. Which is the left and right of the engine? I understand the bank2 is what you see as soon as you open the hood and bank1 is the one closer to the firewall.
