Battery oozing electrolyte - 2009 SE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2009, 10:09 AM   #1 (permalink)
View ww812su's Photo Gallery
Just noticed electrolyte spill on top of the battery. I guess it has been running for some time as it started to corroded the frame structure underneath.
I washed it off with the the solution of baked soda.
I guess it is not normal for the battery to spill (boil out?) acid.
Is this happening because of hot weather? Or overcharging?
Thanks for any insight.
ww812su is offline   Reply With Quote
Old 08-10-2009, 12:55 PM   #2 (permalink)
SSBN's Avatar
View SSBN's Photo Gallery
I had the same problem with my wife's 08 XLE. They tested the battery, cleaned up and repainted the mounts. They should have replaced the battery in my opinion. See if you can get your dealer to replace it. Why doesn't Toyota use a maintenance free battery?
'08 XLE V6 Magnetic Gray, Nav, leather, Heated seats, VSC/Trac, Smart key, Remote start,K&N,35%front/5% rear tint
SSBN is offline   Reply With Quote
Old 08-10-2009, 01:19 PM   #3 (permalink)
Proliphik's Avatar
View Proliphik's Photo Gallery
Funny you mention this, i just noticed the same thing on my battery this morning. Last people to touch it was the Toyota Dealer... Would they actually do something about it?
08 SE - LE GRILLE - LED FOLD MIRRORS - LED TAILS - SWITCH BLADE KEY
TBW INTERIOR ACCENTS - LEATHER/SUEDE SEATS - MTEC H9 LOWS & FOGS
JBL SYSTEM - OEM NAVIGATION - ROOF SPOILER
Proliphik is offline   Reply With Quote
Old 08-10-2009, 04:46 PM   #4 (permalink)
I Eat Accords! W_(^_^)_W
my.rims.are.stock's Avatar
Gameroom cash: $114800
View my.rims.are.stock's Photo Gallery
Gen6
What Dealer? Checkered Flag?
my.rims.are.stock is offline   Reply With Quote
Old 08-10-2009, 05:49 PM   #5 (permalink)
Proliphik's Avatar
Nah, i need to change my location. Just moved to Cali...
Checkered Flag was the best Toyota Dealer ive ever been to
These people over here are sloppy
Old 08-10-2009, 07:05 PM   #6 (permalink)
But really, what may be the problem that leads to the leak?
Old 08-10-2009, 07:13 PM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Excessive heat in the engine compartment or boiling of the electrolyte from overcharging as mentioned are most likely the causes. Most likley the former. You can verify by measuring the charging voltage, should be between 13.5-14.5V.
Take it back to the dealer and have them clean it for you. They should also replace corroded battery cables and fix the body corrosion for free.
Old 08-11-2009, 03:42 AM   #8 (permalink)
View TOYO-ED's Photo Gallery
Also, you wanna spray both terminals with anti-corrosive spray. My Gen4 use to do that a lot; clean it up, and get the spray from your local auto parts store.
TOYO-ED is offline   Reply With Quote
Old 08-11-2009, 09:07 AM   #9 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
The batteries have vented caps so if the pressure builds up too much it will spill out the top. It is not leaking, as such. I've never noticed more than a little moisture on top of the caps however, not actually spilling over. I wonder if the battery has been over filled?
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
Old 08-11-2009, 09:50 AM   #10 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $150432
View Yazovets's Photo Gallery
On my first battery around the terminals I developed some sort of green "salt" build up. When the battery started dying (I had to call the tow truck for a boost once or twice a week) then the green stuff increased even more. The tow truck guy said to clean with water and baking soda but of course I don't want to bother with that dirty job so I had my mechanic put in a new battery. Problem solved. Car starts every time and no green substances. Tow truck man can keep his baking soda hobbies to himself.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
