Timing Belt Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2009, 07:42 PM   #1 (permalink)
View skysi's Photo Gallery
Question Timing Belt Question
Hi ALL!
I bought a used 2002 Camry XLE v6 just 3 weeks ago. It has 98K miles. I know Toyota recommends replacing the timing belt every 90000 miles, so I wonder if it was replaced when the car hit the 90K mark. I kind of hope it was since the car has apparently been taken good care of.
Anyway, I called a Toyota dealer to see how much it would run to check the timing belt, and they quoted $375 - t.b. cost + tax since the job is almost the same as replacing the belt. I suspect the belt has not been replaced, because there's no sticker on the cover, but I'm not sure.
So if I were to replace the belt would it be wiser to go to a Toyota dealer do do it or any mechanic would be able to do it?
Also while I'm still driving without replacement, I'd like to know if my engine (1MZ-FE) is non-interference one. If it's not, then I don't want to take any chances.
Thank you.
skysi is offline   Reply With Quote
Old 08-11-2009, 08:20 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Your 1MZ-FE is non-interference.
2007 Camry 2.4L 5M
Old 08-11-2009, 09:42 PM   #3 (permalink)
Question
Thanks a lot for that info!
Old 08-11-2009, 10:02 PM   #4 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
my cousin also bought a 2002 camry v6 se three weeks ago at 124k on odometer, the original owner told me he never replace the timing belt yet, so i ordered following at a preventive maintainance.
timing belt,
ps belt,
AC belt,
front and rear cam seals, (sign of leaking)
crank seals,
front and rear valve cover gasket,
water pump,
upper and lower coolant hose,
thermostat,
thermostat gasket,
6 spark plugs
egr valve gasket
throttle body gasket
total cost a little over $400 for all parts from bulter toyota at Indiana, free shipped
took me about 1 day to get all done, but at least now i feel safe and don't have to worry about being stranded unexpectedly at the worst possible location when the timing belt decide to break on me.
and towing the vehicle to the shop or home starting at $50 to $80 + mileage.
so i can't justify the cost when the timing belt break, even though it is an non-interference engine.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 08-11-2009, 10:18 PM   #5 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
I did mine at 90k i also got them to do the water pump at the sametime..$750 and change.
2002 Camry SE V6 "Snow White"
Old 08-11-2009, 10:27 PM   #6 (permalink)
timing belt,
ps belt,
AC belt,
crank seals,
water pump,
thermostat,
thermostat gasket,
6 spark plugs
egr valve gasket
I wish I could do that on my own, but I can't. BTW, are all those part OEM or aftermarket?
Old 08-11-2009, 11:58 PM   #7 (permalink)
Did you do this at the dealer's or an independent shop?
Old 08-12-2009, 12:16 AM   #8 (permalink)
Dealer sorry forgot to add that.
And that's in Canadian dollars...so i'd say around 700 or a bit less USD
Old 08-12-2009, 12:58 AM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
It's a non-interference engine. I'd recommend getting a "complete timing belt job" that includes the following parts. You can use aftermarket or OEM, at the dealer or an independent mechanic. Your call.
Here is an old list from rockauto.com:
GATES TCK257 timing component kit $89.79
(timing belt plus two pulleys)
FEL-PRO TCS45890 crank seal $6.27
FEL-PRO TCS45889 cam seal set $8.55
GATES K060410 Alt/AC belt $13.09
GATES K040345 PS belt $8.61
ASCO/AISIN Part # 1610029085 water pump $61.79
Total ~$188 + shipping
If needed: FEL-PRO VS50471R valve cover set (with spark plug tube
seals) $30.79
Originally Posted by skysi View Post
Hi ALL!
Thank you.
Old 08-12-2009, 01:14 AM   #10 (permalink)
Question
seals) $30.79
Thanks a lot, John. This may come in handy. Thanks to bronzemaxell for his list, too.
Old 08-12-2009, 08:05 AM   #11 (permalink)
all item i mentioned are geninue toyota parts, bought from online, bulter toyota dealer, located at indiana
call them for quote, they are selling parts at whole price, about 25% to 30% off list price compare to if you were to walk to local toyota parts department.
3232 HARPER RD INDIANAPOLIS, IN 46240
1-800-692-6396
1-317-848-4214
1-317-846-4511 FAX
there are a few other online toyota dealer, http://www.partznet.com/index.htm is another one.
Old 08-12-2009, 11:14 AM   #12 (permalink)
Gen5
1-800-692-6396
1-317-848-4214
1-317-846-4511 FAX
WOW! Man, thank for the additional info. I can definitely use that
