08 Camry SE Fog Light Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2009, 12:58 PM   #1 (permalink)
ep3er's Avatar
View ep3er's Photo Gallery
I installed a yellow HID foglight kit on my Camry SE and it worked perfectly for 5 months until I blew a fuse. I replaced the 15 amp fuse for a 25 amp and they worked fine.
Two weeks ago I blew the 25 amp fuse, I replaced it and it blew again. I replaced it with a 30 amp one and it blew it. I unistalled the HID kit and installed the OEM 9005 bulds and still blowing up fuses.
I know there's a short somewhere but I can't figure out where. Does anybody have any idea where this short might be or should I just bring the car to the dealer and let them figure it out?
ep3er is offline   Reply With Quote
Old 08-13-2009, 01:34 PM   #2 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $821521
iTrader Score: 16 reviews
View GT-R's Photo Gallery
First, you should NEVER upgrade your stock fuse, your wires are not made for higher amps than what they are designed for.
Second, 08 Camry uses H11 bulbs for fog lights.
And third, dealer might refuse to fix it, cause you had HID fogs, unless you tell them different.
GT-R is offline   Reply With Quote
Old 08-13-2009, 01:46 PM   #3 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
I'd say check the wiring and connections. Make sure there are no exposed wired that may be touching other metal parts. Check the connections so the lead aren't touching each other.
Ditto on what GT-R said as well.
9005 are meant for high beams.. and is a higher wattage
My Partial Partout!!!
Photo Album
Old 08-13-2009, 01:54 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
I love these stories..........
Old 08-13-2009, 01:56 PM   #5 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Me3
Old 08-13-2009, 01:57 PM   #6 (permalink)
"Circle of trust"
View catric69's Photo Gallery
Did you install a relay along with the HID's?
catric69 is offline   Reply With Quote
Old 08-13-2009, 03:30 PM   #7 (permalink)
ep3er's Avatar
Sorry, I meant H11's instead of 9005's. I uninstalled everything and it looks just like stock. I checked all the wiring and I cannot detect anything.
I did replaced the 30 amp fuse with the 15 amp it calls for and still blew it.
Old 08-13-2009, 03:31 PM   #8 (permalink)
ep3er's Avatar
I did.
Old 08-13-2009, 04:04 PM   #9 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Looks like the relays cause nothing but trouble.
