Nitrogen filled tires? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2009, 06:06 PM   #16 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
fyi, the rear tires are normally the ones to pick up nails due to centripetal force on a nail via the front tires.. i would jack it up and spin the tire to see if a nail is in there.
MrSo0h0o is offline   Reply With Quote
Old 08-26-2009, 07:40 PM   #17 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Just another example of wild supposition.....................
Old 08-26-2009, 07:57 PM   #18 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
You can "top off" with regular air. Costco switched over to nitrogen years ago. I can "top off" by driving to Costco. For me there is no reason to go anywhere else.
Originally Posted by bearclaw1017 View Post
So, I bought a Camry SE 09 back in March with the nitrogen filled tires. The tire pressure light is going on so I want to check them and fill them up with my air pump but I can't do it right? Do I have to take it into a dealer to fill it?
Old 09-22-2009, 02:10 PM   #19 (permalink)
View AlmightyCamry777's Photo Gallery
Originally Posted by asn13oy View Post
I think it's worthless unless you're able to purge all the normal air out with pure nitrogen even before you begin to fill to your preferred pressure. Then there's the issue of cost for this service as well as the increased cost of the occasional "topping-off".
As previously stated, just having the moisture/vapor removal on the compressor is enough.
You should try putting helium in your tires..lol.
I thought of doing that but wouldnt i float away? Also if i tried to scream for help everyone would laugh at me with my funny voice.
AlmightyCamry777 is offline   Reply With Quote
Old 09-23-2009, 07:26 PM   #20 (permalink)
Costco has been filling tires with nitrogen for a while now. I wonder if they'll be willing to spare a bit for non-customers.
If you have a slow leak, get it back to the dealer for warranty service. I think tires are covered under a separate warranty? It may be that the bead isn't properly mounted to the rim? Because continuous slow leak will be annoying down the road.
In between nitrogen fills I like to use a blend:
Nitrogen (N2) 780,840 ppmv (78.084%)
Oxygen (O2) 209,460 ppmv (20.946%)
Argon (Ar) 9,340 ppmv (0.9340%)
Carbon dioxide (CO2) 383 ppmv (0.0383%)
Neon (Ne) 18.18 ppmv (0.001818%)
Helium (He) 5.24 ppmv (0.000524%)
Methane (CH4) 1.745 ppmv (0.0001745%)
Krypton (Kr) 1.14 ppmv (0.000114%)
Hydrogen (H2) 0.55 ppmv (0.000055%)
Nitrous oxide (N2O) 0.3 ppmv (0.00003%)
Xenon (Xe) 0.09 ppmv (9x10−6%)
Ozone (O3) 0.0 to 0.07 ppmv (0% to 7x10−6%)
Nitrogen dioxide (NO2) 0.02 ppmv (2x10−6%)
Iodine (I) 0.01 ppmv (1x10−6%)
Carbon monoxide (CO) 0.1 ppmv
Ammonia (NH3) trace
Thanks for the replies guys. After reading your responses and a few other sources it makes sense just to put in air. It's what I did. Just used my air pump.
Odd thing is, all tires were good except for the rear left. That one was down about 4-5 pounds. I'll monitor it and hopefully there's not a leak.
Old 09-23-2009, 07:47 PM   #21 (permalink)
i love emmanuelle chriqui
LXS-mode's Avatar
View LXS-mode's Photo Gallery
Ammonia (NH3) trace
you didn't have to google "AIR Composition.
What is it about...Stance? Flushness? Stretch? or Pokin Out?
Clean...Elegant...Simple...yet so GANGSTA!!!
LXS-mode is offline   Reply With Quote
Old 09-24-2009, 01:01 AM   #22 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
Originally Posted by TTM77 View Post
So the max U can fill is only twice (2 set of arm and leg) lol
it won't hurt your tires much, just fill it if u need. Make sure u fill it when its dry too to minimize the amount of H2O.
And I think Toyota use regular air pump too.
If U want go to Costco, they fill using N too.
Ps. Do the search, this topic was covered.
That's what I did. Their gauge is neat-o too. They set it to whatever PSI you want, and the thing beeps when you meet it. FREE too.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
