Nitrogen filled tires? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2009, 06:56 PM   #1 (permalink)
View bearclaw1017's Photo Gallery
Gen6 Nitrogen filled tires?
So, I bought a Camry SE 09 back in March with the nitrogen filled tires. The tire pressure light is going on so I want to check them and fill them up with my air pump but I can't do it right? Do I have to take it into a dealer to fill it?
bearclaw1017 is offline   Reply With Quote
Old 08-25-2009, 07:00 PM   #2 (permalink)
Gameroom cash: $255930
View LE05's Photo Gallery
what do you think the air we breathe has a percentage of? nitrogen. you should be fine with filling your tires with the air pump. though you could take it into the dealer if you want, but it'll probably cost an arm and a leg when you could fill your tires for free.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 08-25-2009, 07:51 PM   #3 (permalink)
Joined the dark side. :D
Gameroom cash: $581791
View workerant's Photo Gallery
So the max U can fill is only twice (2 set of arm and leg) lol
it won't hurt your tires much, just fill it if u need. Make sure u fill it when its dry too to minimize the amount of H2O.
And I think Toyota use regular air pump too.
If U want go to Costco, they fill using N too.
Ps. Do the search, this topic was covered.
workerant is online now   Reply With Quote
Old 08-25-2009, 08:11 PM   #4 (permalink)
View WesB's Photo Gallery
The reason for using nitrogen in tires is b/c nitrogen is a dry gas (no moisture) therefore tirepressure should stay the same when the temperature outside varies. It's also supposed to give you better gas miliage b/c your pressures won't vary.
I used to work at a tire shop.
WesB is offline   Reply With Quote
Old 08-25-2009, 09:19 PM   #5 (permalink)
View titleist's Photo Gallery
The Oxygen You Breathe Is 78% Nitrogen. The Machines That Put Nitrogen In You Car Guarantees 81% Nitrogen. Do Not Pay For Nitrogen. Just Put Oxygen In Your Tires And Drive On.
titleist is offline   Reply With Quote
Old 08-25-2009, 09:28 PM   #6 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184280
View DrewsCam's Photo Gallery
just add regular air and off you go
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 08-25-2009, 09:31 PM   #7 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $2513100
Any tire shop or service station worth their salt will have a moisture removal as part of their air inflation system. Easy enough for the layman to check (besides asking) just lay on the air and if it has no recovery system it'll spit water.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 08-25-2009, 09:32 PM   #8 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
No, the air you breathe is 78% nitrogen................
Old 08-25-2009, 10:41 PM   #9 (permalink)
I Eat Accords! W_(^_^)_W
my.rims.are.stock's Avatar
Gameroom cash: $111600
View my.rims.are.stock's Photo Gallery
Gen6
Oooh! You just got served!!
my.rims.are.stock is offline   Reply With Quote
Old 08-26-2009, 01:49 AM   #10 (permalink)
2AR-FE_VX40
Gameroom cash: $127730
View asn13oy's Photo Gallery
I think it's worthless unless you're able to purge all the normal air out with pure nitrogen even before you begin to fill to your preferred pressure. Then there's the issue of cost for this service as well as the increased cost of the occasional "topping-off".
As previously stated, just having the moisture/vapor removal on the compressor is enough.
You should try putting helium in your tires..lol.
asn13oy is offline   Reply With Quote
Old 08-26-2009, 01:58 AM   #11 (permalink)
Do you feel lucky?
TrailDust's Avatar
I think the MythBusters did that....didn't do doodly squat....
2002 Avalon XL
Old 08-26-2009, 02:55 AM   #12 (permalink)
"Everyone Lies"
Dna_splice's Avatar
View Dna_splice's Photo Gallery
put methane...
'03 SE i4 <3
"Si vis amari ama"[If you want to be loved, love.]
Dna_splice is offline   Reply With Quote
Old 08-26-2009, 03:00 AM   #13 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Originally Posted by Dna_splice View Post
put methane...
Via a duct from the seat bottom cushions.
2007 Camry 2.4L 5M
Old 08-26-2009, 08:35 AM   #14 (permalink)
Indy Tech's Avatar
View Indy Tech's Photo Gallery
Post
This makes good reading but every one has there own version and ideas
as to use or not use nitrogen filled tires myself i agree with this link
http://ahotcupofjoe.wordpress.com/20...-tires-a-scam/
Indy Tech is offline   Reply With Quote
Old 08-26-2009, 06:44 PM   #15 (permalink)
Thanks for the replies guys. After reading your responses and a few other sources it makes sense just to put in air. It's what I did. Just used my air pump.
Odd thing is, all tires were good except for the rear left. That one was down about 4-5 pounds. I'll monitor it and hopefully there's not a leak.
