'03 Camry Chugging & P0446 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2009, 09:57 PM   #1 (permalink)
View Fluxuated's Photo Gallery
A few days ago, I checked out my parents '03 Camry (4cyl) for a check engine light. I Plugged a ScanGaugeII into the OBDII Port to read the code and pulled a P0446, I reset it.
Ever since doing that, the car has been chugging at idle. When cold it will Idle fine at 1,000RPM, when warm it's 200RPM or less and Stalls waiting at a light.
Now I plugged in this ScanGauge II in the past, and it caused the car to chug, at idle when plugged it, but when it was unplugged it ran fine, so I've never plugged it in again except to read this code.
The first thing I did was check the Gas cap to see if it was loose (In response to P0446) and it was fine, I replaced the PCV Valve (Starting at a cheap replace, working upwards) and no difference, I checked all the Lines running from the PCV Valve, the VSV and hoses, and looked for anything else I could find under the hood. I also stuck my head under the car and checked around the Charcoal Canister, nothing abnormal.
Any idea what it Might be? We even disconnected the battery for a half hour and reconnected, hoping it was something the ScanGaugeII Did, and could be reset with a battery disconnect.
Any help is deeply appreciated. Thanks.
Fluxuated is offline   Reply With Quote
Old 08-27-2009, 10:15 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
This has been covered numerous times...........SEARCH
Old 08-27-2009, 10:17 PM   #3 (permalink)
I have searched, thanks for your advice. Perhaps you can point me in the right direction, since I can't seem to solve it?
Old 08-27-2009, 10:26 PM   #4 (permalink)
'07 XLE
CEL - P0446 !!! Help needed
and your Service Manual also....
Old 08-27-2009, 10:34 PM   #5 (permalink)
Thanks for the link, I read through it, but don't see any instances of Chugging at Idle. I'm not sure this is a P0446 Problem or something else. P0446 has not come back since I cleared the code, actually no codes have popped up, despite the engine running to low RPM at idle.
Open to other suggestions, thanks.
Old 08-28-2009, 12:29 PM   #6 (permalink)
Anyone, else have any ideas? Thanks.
Old 08-28-2009, 12:53 PM   #7 (permalink)
'07 XLE
Gen6
Clean your Throttle Body, MAF sensor, PCV valve if you have one.
Old 08-28-2009, 07:34 PM   #8 (permalink)
View charlie_bravo's Photo Gallery
Yes, clean the Throttle Body. Have had to that twice(same idle probs) with no codes...!
charlie_bravo is offline   Reply With Quote
Old 08-28-2009, 08:50 PM   #9 (permalink)
I'll try that, thanks for the suggestions.
Old 08-29-2009, 12:33 AM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $400224
View BlackCamSe's Photo Gallery
Just throwing parts at a vehicle isn't the proper way to diagnose it.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 09-22-2009, 03:08 PM   #11 (permalink)
View AlmightyCamry777's Photo Gallery
Since you didnt post back, the cleaning must have fixed the problem? If you still have the engine problem, the next thing i'd suspect is the EGR valve.
AlmightyCamry777 is offline   Reply With Quote
