Allen/Hex wrench size for transmission plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2009, 03:26 PM   #1 (permalink)
View 89molavi's Photo Gallery
My ATF needs refreshing at ~ 50KM. I have got the Type IV ATF and the washer. I was checking my box and the largest allen I have is 6mm. I think the tranny drain plug is 10mm, but before buying one I need to know. I might end up just buying the one size.
It is a 2005 LE with the 5 spd auto tranny. TIA
89molavi is offline   Reply With Quote
Old 08-28-2009, 03:52 PM   #2 (permalink)
View bcozimazn's Photo Gallery
I believe its 10mm.
bcozimazn is offline   Reply With Quote
Old 08-28-2009, 07:36 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
It's 10mm, but you should get one that will attach to 3/8" ratchet handle. I've not seen one of the L-shaped ones that give you enough leverage to open the plug.
2007 Camry 2.4L 5M
Old 08-28-2009, 08:58 PM   #4 (permalink)
pedron
Guest
Posts: n/a
View pedron's Photo Gallery
I agree with the above statement. Get yourself a set like these.
Old 08-28-2009, 10:52 PM   #5 (permalink)
Gameroom cash: $498830
View JohnGD's Photo Gallery
You mentioned KM. Are you in the States?
If so you can get them at Sears, or better yet, get a whole set at your local Harbor Freight:
http://www.harborfreight.com/cpi/cta...emnumber=98229
Old 08-28-2009, 10:52 PM   #6 (permalink)
Got it, actually bought only the 10mm for now. Not a fan of hex! Will let you know how the oil change goes. Thanks.
Old 08-29-2009, 09:56 AM   #7 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
look @ my website.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 08-30-2009, 01:07 AM   #8 (permalink)
Okay, changed the fluid. Looked dirty considering I have only 48000 HWY miles. Granted they are South CA HWY miles, where you could be "parked" on the fwy for a while.
Couple of pointers;
In the owner's manual I could not find how to check the fluid level. 95% of cars it is in park, but I know of some Mitsu's and Mopar products that you have to check in Neutral.
Also, the "crush" washer is really just a metal washer, so I am not sure if I had to change it. It dropped in the pan and initially I thought it didn't have one, until I drained the pan.
Old 08-30-2009, 04:39 PM   #9 (permalink)
To check the transmission fluid level, warm up the car to normal operating temperature, move the shifter through all the positions and back to park. Park vehicle on level surface, leave engine running with car in park and parking brake engaged. You will use the hot portion of the dipstick.
2007 Camry 2.4L 5M
Old 08-30-2009, 06:26 PM   #10 (permalink)
Gameroom cash: $255930
View LE05's Photo Gallery
check the fluid level by first bringing the car to operating temperature, approx 5 - 10 min of drive, give or take. Once the temp is up to operating temperature, with your foot on the brake, cycle through the gears down and up, PRND32L - L23DNRP. Leave the car running and in park, you can now check the fluid level. Take the dipstick it out, wipe it, put it back in ALL the way, then take it back it out to check the level. that's what my owner's manual says more or less.
as for the crush washer, you should ideally replace it every time you change the oil (transmission or motor). you can reuse it, but for ~$1, you might as well replace it. its cheap insurance against the drain bolt leaking.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 08-30-2009, 11:53 PM   #11 (permalink)
The Connoisseur
CharmCityES's Avatar
nice writeup LE05!
id say something else but youve got the whole nine yards covered.
The "Executive Sedan"
Old 08-31-2009, 11:17 AM   #12 (permalink)
View ChiTDI's Photo Gallery
Alternative
You could use a Torx 55 male socket if your hex is rounded or rusted. The socket (10mm hex or the Torx) fits into the bolt recess fairly well so make sure it bottoms before turning the ratchet. There are horrror stories about rounding the drain bolt so be mindful when you do it.
ChiTDI is offline   Reply With Quote
Old 08-31-2009, 09:13 PM   #13 (permalink)
vvti-me's Avatar
View vvti-me's Photo Gallery
i'm a mechanic and work on these all the time. its a 10mm
vvti-me is offline   Reply With Quote
