2009 I4 Camry Jurky startup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2009, 10:41 AM   #1 (permalink)
View camlex's Photo Gallery
Hello,
Do i needs to clean TB? pushing gas paddle car start with jurk not smooth starting.
Thanks in advance.
camlex is offline   Reply With Quote
Old 09-06-2009, 10:46 AM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
are you letting the car settle into normal idle? How high is your idle when you put it in gear? and its pedal, not paddle
MrSo0h0o is offline   Reply With Quote
Old 09-06-2009, 10:52 AM   #3 (permalink)
yes, normal idle runs between 700-800 rpm
sorry about "Pedal"
Old 09-06-2009, 11:02 AM   #4 (permalink)
MrSo0h0o's Avatar
i know its a new car and all, but check your motor mounts.
Old 09-06-2009, 11:45 AM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
we need more info. Are you saying the car wont start UNLESS you give it gas? Or if you just start it and put it into gear it jerks? Let the car sit for a few seconds before putting it into gear.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 09-06-2009, 03:38 PM   #6 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
check all your fluids and battery also.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 09-07-2009, 11:34 AM   #7 (permalink)
what i was saying was everything is fine. car runs great. only problem is when you are on stop sign or light and you push gas, start with jurk, not smooth like my others toyota's. may be they change starting torque.
or should i clean TB?
Thanks,
Old 09-07-2009, 11:37 AM   #8 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
is it more like a drag race launching....
or just because you press on the gas pedal too hard too fast....
or does it accelerate and then jerk alittle bit.
skyxliner is offline   Reply With Quote
Old 09-07-2009, 02:23 PM   #9 (permalink)
View SimplyACruiser's Photo Gallery
I'm kinda lost
2009 Camry; Blue Ribbon
SimplyACruiser is offline   Reply With Quote
Old 09-07-2009, 02:47 PM   #10 (permalink)
씨발
Thanks,
ah okay. when u said startup in the OP, startup usually means cranking your engine to turn on your car.... Thats why everyone was confused.
This is actually normal of the camrys. The gas pedal is really sensitive and has a lurchy start. Learn to modulate correctly.
AdvanceSpeedShop
Old 09-07-2009, 07:25 PM   #11 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
yea paul is right. it's pretty normal. specially if car is new. it'll get better as it's worn in and you learn to drive it.
WrongFitmentCrew#628
Old 09-07-2009, 07:41 PM   #12 (permalink)
Thank you.
