Some 2007-2010 Camrys may exibit a vibration or pulsation condition when braking. New front brake pads are available to address customer concerns. Follow repair procedures....
1. Machine rotors on car. If below minimum thickness replace rotors.
2. Replace front pads with improved kit.
3. Remove rear pads and check pad material code on lower left corner. If not D6247-FF, replace pads.
LOL such fools (Toyota) in finally publishing this. I've had this problem with my first set of brakes and now I have the same problem developing with my second set of brakes.
From what I have noticed, once you do a new brake job, you have about 30000-35000km before the trouble starts.
My mechanic had alleviated the problem precisely by re-machining my front rotors. This helped for about 5000-10000km but basically once you machine them a second time, if you get problems again, you have to replace the rotors and pads the third time around.
__________________ 2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Wouldn't this just fall under normal maintenance though? Like resurfacing rotors at first brake pad change, which is usually recommended for most cars anyways.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Excellent! Thanks for the information. Just curious, will this TSB also apply if you are past the standard 36k miles Toyota Comprehensive Warranty, but have the Toyota Platinum Extended Warranty? Either way, I'm at 35k, so it's perfect timing.
