T-SB-0284-09 August 21, 2009 Sunvisor Mount Loose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2009, 12:15 PM   #1 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6 T-SB-0284-09 August 21, 2009 Sunvisor Mount Loose
2007 – 2010 Camry, Camry HV
If the driver and front passenger sunvisors are operated forcefully, the mounting area of the sunvisor on the vehicle body may become damaged. If this has occurred, the sunvisor may become loose from the mounting area located on the headliner. To address this condition, newly designed
mounting brackets have been made available to reinstall the sunvisors. Follow the procedures in this bulletin to install the mounting brackets.
This TSB applies to vehicles produced
BEFORE the Production Change Effective VINs shown below.
PLANT LINE DRIVETRAIN PRODUCTION CHANGE EFFECTIVE VIN
TMMK Line 1 L4 4T1BF3EK#AU017501
TMMK Line 1 V6 4T1BK3EK#AU101208
TMMK Line 2 L4 4T1BF3EK#AU521414
TMMK Line 2 L4 4T1BK3EK#AU600223
TMMK Line2 Hybrid 4T1BB3EK#AU114358
SIA L4 4T4BF3EK#AR031582
Tsutsumi L4 JTNBF3EK#A3002320
Tsutsumi L4 JTNBK3EK#A3048854
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle’s in-service date.
Repair Kit basically replaces installs plastic brackets in the roof and installs 2 screws that attach the visor bracket to the roof.
Old 09-08-2009, 03:19 PM   #2 (permalink)
TN Member
View 02camrySE's Photo Gallery
Thumbs up
Thank you for this info, as well as your other TSB info regarding the brake vibration!
My car is in the shop today for the issues I've been having stated in another thread, and one of which is the sunvisors came out. I contacted my service rep and asked to check into these other two issues so we'll see what the outcome is.
Thank you!
02camrySE is offline   Reply With Quote
Old 09-08-2009, 08:43 PM   #3 (permalink)
View hossmaster's Photo Gallery
too bad this doesn't cover the actual sun visor breaking, i am out both sun visors because of the stupid plastic mechanism that turns the light on.
hossmaster is offline   Reply With Quote
Old 11-11-2009, 05:56 PM   #4 (permalink)
View Electron2002's Photo Gallery
FYI, the brackets are plate steel. It would take a elephant to pull them out of there.
Electron2002 is offline   Reply With Quote
Old 08-22-2011, 12:55 PM   #5 (permalink)
View steve58's Photo Gallery
Replacing Visor
My sister had an 07 Camry, the visor broke so she ordered another ($100) and they wanted $60 bucks to replace it. She brought it to me, I popped off the plastic cover (where the screws used to be in older visors) and popped the old visor out. Once you have the old visor out, it's pretty easy to see how the new one goes in, just remove the retainer clips if they stayed in the roof. The new visor came with the new retainer clips mounted. Remove the plastic cover from the new one because that is how the new retaining clips stay spread out and hold the new visor. Press the new visor into the holder, then pop the plastic retainer into its place and it will hold the new visor in place. I took the old visor apart to see why it broke, and it's VERY POOR engineering on Toyota's part. Someone really missed it on this, my guess is the new visor won't last two years either....
steve58 is offline   Reply With Quote
