REVERSE to DRIVE (AT) - hard kick - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2009, 02:10 PM   #1 (permalink)
View agalinski's Photo Gallery
Gen5 REVERSE to DRIVE (AT) - hard kick
2002 V6 Camry; AT. For quite some time, the vehicle has a hard kick when you switch from REVERSE to DRIVE; definitely want a firm foot on the brake pedal. The dealer claims this is because the engine is cold. Admittedly, the Reverse to Drive kick is softer after the car has been driven for a while, but still a kick. On a possibly related note, I just drained and refilled the ATF and found only 3.25 quarts of Type T-IV. Last drain and fill was done at the dealer. If this is short, could this be the cause of the hard kick when switching from Reverse to Drive? Shouldn't it be 3.7 quarts for an AT drain and fill? Thank you.
agalinski is offline   Reply With Quote
Old 09-07-2009, 02:12 PM   #2 (permalink)
RX300 + CAMRY
View lamar411's Photo Gallery
That also happens to me when the car is cold. But happens in the middle summer once in a while. Same thing in my Lexus sometimes it feels like it doesnt want to shift.
lamar411 is offline   Reply With Quote
Old 09-07-2009, 02:48 PM   #3 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
Do you switch from reverse to drive when your car is completely stopped? or while your car is still rolling?
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 09-07-2009, 03:12 PM   #4 (permalink)
In this car, I always make sure to come to a complete stop after reverse and hold the brake firmly. Anything less and you'll get whiplash from the kick! When holding the brake and switching from R to D, there is a thud. Then I know it is okay to let go of the brake and start rolling forward. We've owned the car from day 1, but my wife is the primary driver. I am certain it wasn't always like this.
Old 09-07-2009, 07:26 PM   #5 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
yea it could be the ATF. check levels are ok and your using the right one.
WrongFitmentCrew#628
Old 09-07-2009, 09:24 PM   #6 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
check your motor mounts. with a 2002, they may be worn out/broken
MrSo0h0o is offline   Reply With Quote
Old 09-07-2009, 10:46 PM   #7 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
+1... How's your shifting? Does your car vibrate at a stop?
My Partial Partout!!!
Photo Album
Old 09-10-2009, 07:56 PM   #8 (permalink)
I'll check the motor mounts, but only have 60,000 miles; family driving. Shifting between gears is fine; no vibration at stop. Only Reverse to Drive; before the engine is warm... at any time of year; live in the Chicagoland area.
Old 09-11-2009, 01:23 AM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
That should be the U140E transmission. IMO the entire Aisin U-series is bad news. If this thing is like the U240 series then sure there is a fluid circuit problem. But I'd think it has more to do with occasional shift problems as the fluid couldn't empty itself quickly enough or some thing like that.
However, your issue may be related to something as simple as an accumulator that absorbs shift shocks. It's simply a spring loaded piston in a chamber. If the o-ring around it leaks then it loses it's function.
Old 09-11-2009, 02:55 PM   #10 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I don't particularly care for the U-series transmissions, at least the ones I've driven with. Both mine and an aunt's '05 Avalon have a clunk once in a while when you're driving, and the Avalon is a little slow to shift into DRIVE and you can definitely feel it too.
The transmission in my mom's gen 3.5 (A-series?) is smoother and less quirky than mine for sure.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
