Throttle Body Problem with 06 Camry 33k Miles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2009, 06:14 PM   #1 (permalink)
View twoslo's Photo Gallery
Unhappy Throttle Body Problem with 06 Camry 33k Miles
My sister has a 2006 CE Model 5 Speed Manual. On Sunday her car stuttered while cruising 35MPH and the steering wheel locked, she pulled over and restarted the car. After the restart, the car through a CEL. The car then started to shake while idling and it would randomly go from 700-1500 RPM. The car would stall if trying to give it any gas.
The car was towed to Toyota this morning where they diagnosed the throttle body as being STUCK OPEN. They told my sister that the entire throttle body needed to replaced and they want to charge her $1500 for the whole ordeal.
Has this problem happened to anyone before? I tried searching but had no luck finding anything regarding this problem for the newer camrys. Is there perhaps a DIY on replacing the throttle body or can anyone point me in the right direction?
Any help would be greatly appreciated. Thanks
twoslo is offline   Reply With Quote
Old 09-08-2009, 06:57 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Seems high...labor shouldn't be that much.
New Throttle body, camry, 2.4l, 05-06
$874.02 list, $604.28 on-line + shipping
Out of Warranty?
Old 09-08-2009, 10:30 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Out of Warranty?
He's right. Order it on-line and take it to a buddy or an independent shop. Its an easy job. The throttle body is only held on by 4 screws, and a few vacuum hoses
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 09-09-2009, 12:01 AM   #4 (permalink)
'07 XLE
Gen6
You might find one at a wrecking yard. Cheaper but unknown condition.
Old 09-09-2009, 06:44 AM   #5 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
Have they tried to clean it, first?
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 09-09-2009, 06:59 AM   #6 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
That's not how you make money my friend.
To OP: buy it yourself and do it yourself or with a buddy who knows what they are doing.
Redline_Me is offline   Reply With Quote
Old 09-22-2009, 02:03 PM   #7 (permalink)
View AlmightyCamry777's Photo Gallery
Its been a few weeks so you probably already paid to fix it - but Luna2 is right, it might have just needed a cleaning (for $3 for a can of cleaner rather than $1500.) You dont say whether you've got the 4 or the V6, but i have the V6 and let me tell you, the inside of the throttle body gets filthy after only about 20,000 miles. The 4 cylinder engines are even worse for this because the IAC (idle air control valve) on most of them is right underneath the butterfly and it too, gets filthy, which can make the car not start, not idle, or run bad all the time, depending on where it is stuck at.
throttle bodies do of course wear out from time to time, because they are aluminum - and the portion inside where the steel butterfly touches them gets worn over time, allowing too much air in at idle. This is especially so for a manual transmission car due to all the throttle opening and closing going on. But for a car as relatively new as a 2006 camry to have this condition either means its got hella miles on it (way over 100,000), or the TB is physically broken or cracked. I suspect the mechanics might be trying to jack your sister on the repair bill.
AlmightyCamry777 is offline   Reply With Quote
Old 09-24-2009, 08:09 PM   #8 (permalink)
View tdwnok's Photo Gallery
www.topix.com has a world of info also with really angry folks paying upwards of $1500 for a throttle body replacement at low mile. Did mine myself without a manual for $250. Just found one from a wrecked car.
One and a half hour job. If you get a dianostic of P2112 it means your TAC (Throttle Actuator Control) permanetly connected to your throttle body fialed. Try cleaning it first with throttle cleaner. But if that does not work find a salvage yard. I was so upset that I bought several (one for my trunk) so if you can't find one let me know. If you have a 2004 - 2005 4 cylinder Camry. Actually I think it fits the RAV4 too. Good luck. Tommy
tdwnok is offline   Reply With Quote
