Has Anyone Tried YellowBox? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2009, 03:46 PM   #1 (permalink)
View MrObvious's Photo Gallery
Seeing my speedo reads 5MPH faster than what I'm going, I am in the mood to recalibrate it. It seems YellowBox may be my answer but in e-mailing them they want to know if the speedometer is hall effect or inductive coil in order to send me the right product. I haven't had the money to go to the mechanics and ask about checking the wires or whatever since I don't know where it is located. So anyone have any tips or advice?
MrObvious is offline   Reply With Quote
Old 09-09-2009, 04:27 PM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
What year is your car?
The gen6 averages the pulses from each of the 4 wheels and that ECU sends average that to IPC (Instrument Panel Cluster), which is buffered to other devices. So you may need a unit that reads the actual pulses and "subtracts the overage" to make the "spedo" read properly. The one I saw was programmable.
There is one out there, don't remember where......
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 09-09-2009, 06:25 PM   #3 (permalink)
YellowBox supposedly recalibrates the speedo but more information would be helpful. Thanks for the help so far Luna.
Old 09-09-2009, 06:38 PM   #4 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Mine reads 3 MPH fast, and I've seen others mention this as well on the gen 5.5.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 09-09-2009, 07:29 PM   #5 (permalink)
Twin & (1 of 8)
Luna2's Avatar
I looked at the specs for the "Yellow Box", it looks like it would work. The install connections are basic and for a motorcycle, but are doable. If I were to install one, I would install it behind the glove box. The connector that has the speed signal from the ABS Skid ECU (mounted under the hood) first appears on the inside, at connector AE6 pin 6 in the glove box area. I would still have to locate the (clean) power source and ground connection point(s). Plus this area is dry and is well protected.
MFG 02/25/2010
Stock, Shucks!
Old 09-09-2009, 07:43 PM   #6 (permalink)
Awesome Luna. Any more information is appreciated.
Old 09-09-2009, 08:27 PM   #7 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
So, you don't have the money to go to a mechanics to check wires but want to buy a yellowbox instead and install it (from your words you might need help with that at some cost)....to correct for a 5MPH offset?
How about simply remembering true speed is "-5" and call it a day. Works for me everyday.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 09-09-2009, 09:20 PM   #8 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
+1. -(2-3) mph for me.
Odometer within 1% though.
Old 09-09-2009, 10:02 PM   #9 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
how do u know it's off by that much? cop told U?
workerant is offline   Reply With Quote
Old 09-09-2009, 10:55 PM   #10 (permalink)
2007 Camry SE V6
Gameroom cash: $133290
View thrawnis's Photo Gallery
Personally, I want my speedometer and odometer to reflect my true mileage. Even a 5mph difference makes a big difference over the course of the car's life.
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is offline   Reply With Quote
Old 09-10-2009, 12:00 AM   #11 (permalink)
I know it's off but I wanna see about fixing it.
Old 09-10-2009, 03:11 AM   #12 (permalink)
Twin & (1 of 8)
Luna2's Avatar
1% @ 60 mph = +o.6 mph
2% @ 60 mph = + 1.2 mph
3% @ 60 mph = +1.8 mph
4% @ 60 mph = +2.4 mph
5% @ 60 mph = +3.0 mph
6% @ 60 mph = +3.6 mph
7% @ 60 mph = +4.2 mph
So a speedometer reading 61 mph when you are actually doing 60 mph is just under a 2% error.
The following is from ME manual page 39:
Reference: mph (U.S.A.)
Chassis dynamometer indication Acceptable range
20 mph 20.0 to 23.0 mph
40 mph 40.0 to 43.5 mph
60 mph 60.0 to 64.0 mph
80 mph 80.0 to 84.5 mph
100 mph 100.0 to 105.0 mph
120 mph 120.0 to 125.5 mph
140 mph 140.0 to 146.0 mph
160 mph 160.0 to 166.5 mph
NOTICE:
Tire wear as well as over or under inflation
will cause errors.
(2) Check the deviation from the acceptable range
of the speedometer indication.
Toyota’s speedometer indicator specification, for maximum (+ only) error is (rounded up) 6.67% at 60 mph. (So any (–) error is an immediate cause for a speedometer replacement IF all other parameters are correct.)
Note: I read my vehicle speed via the DLC3 (OBDII) connection with my computer, compared to the speedometer needle, the delta was +3.0 mph. Further checks indicated a higher delta when slowing down, rather than the normal accelerate to the measured speed. My computer speed reading was correct when tested on a measured 3 mile flat surface road, on cruse and a stop watch. End result, within Toyota Specifications and no correction was made.
The dealer can test the speedometer needle error with the Intelligent Tester by entering the following menus:
Diagnosis / OBD/MOBD / METER / ACTIVE TEST (From ME manual page 39)
MFG 02/25/2010
Stock, Shucks!
Old 09-10-2009, 03:18 AM   #13 (permalink)
View Lydia's Photo Gallery
Great! Thanks for sharing guys!
Lydia is offline   Reply With Quote
Old 09-10-2009, 12:11 PM   #14 (permalink)
Wow nice information but I checked up on my dealer and they said it would require a new instrument cluster because 5 MPH was within their acceptable range. :\
Old 09-10-2009, 12:29 PM   #15 (permalink)
'07 XLE
Gen6
???????????????? That's what was said.
